JohnWillis
Message 1 of 4
Has anyone else experienced a problem running the BT broadband speed tester on the bt.com website?
For the last two or three weeks I have been unable to test my broadband download speed via the bt.com website and/or the MyBT app.  The BT Wholesale speed tester works OK as does the one at fast.com and Which.  I have had two engineers visit me today and they agree my hardware is working as expected.
I have Ultrafast 1 broadband, BT PLus as well a s one of the new BT Hub2 routers.
All my services i.e. broadband and telephony are working OK.  It is just the speed tester mentioned above, that is causing a problem.  No one I have liaised with on the phone has been able to assist me with this one.
3 REPLIES 3
DUCASSOS2020
Message 2 of 4
Re: Has anyone else experienced a problem running the BT broadband speed tester on the bt.com websit
there has been problems on website .
nbedford
Message 3 of 4
Is this the same one you get to if you follow the link in the HH6? It hasn't worked for since day 1, I'm on Ultrasfast 2 (18 days so far)
conrad
Recognised Expert
Message 4 of 4
I'm on Superfast Fibre and the tester hasn't worked properly since early Sept which is when I first used it. See message 56 on this thread for what I got at best  https://community.bt.com/t5/BT-Fibre-broadband/Unusual-appearance-of-the-BTW-speed-test/td-p/1871395...
