dan44762000
Message 1 of 3
Having an issue with Ipv6 connection
So i got rid of the HomeHub and bought a Archer VR600 , got it all set up fine with WiFi and Ipv4 but i enabled IpV6 this morning and did a test over on IPV6 test website.
Got a score of 18/20 and the bad one said
"Your router or firewall is filtering ICMPv6 messages sent to your computer. An IPv6 host that cannot receive ICMP messages may encounter problems like some web pages loading partially or not at all."
I dont use the Windows fiirewall,its turned off , infact i dont use a Firewall at all , so what settings do i need to change to get this a 20/20 score
 EDIT - nevermind,i double checked the Firewall settings and it had re-enabled due to the new connection,i have turned it off now and i am getting a 20/20 score
Daniel
2 REPLIES 2
Liam_
Recognised Expert
Message 2 of 3
Re: Having an issue with Ipv6 connection
You don't have a problem per se.  The router is just not responding to pings from the internet.  This is good from a security point of view.  It's unlikely to cause any issues, all the routers I have used have been configured not to respond to ping. (ICMP).
The test site indicates all is working as it should.
licquorice
Message 3 of 3
ICMPv6 is somewhat different, it is used for neighbour discovery.
https://tools.ietf.org/html/rfc4861
