happysteveo
Message 1 of 22
Help Please: BT Fibre connection dropping out
Hi all,
We have had fibre for some years now, over the last year I have noticed the connection stopping a lot more, leading to me manually disconnecting and reconnecting to the wifi to get a web page to start loading, for example.
Can anyone suggest what we can do please?
21 REPLIES 21
albertj
Expert
Message 2 of 22
Re: Help Please: BT Fibre connection dropping out
Does this happen over ethernet?
What colour does the hub go during these problems?
Can you dial 17070, option 2 with corded phone. Should be silent between announcements.
Also post hub stats:
Go to 192.168.1.254 in browser
HH6- then advanced settings then technical log information
HH5- then troubleshooting then helpdesk
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 3 of 22
Post hub stats  if hh6 then advanced setting GSM then technical log information
Check for line noise  dial 17070 option 2 should be silent and best with corded phone
happysteveo
Message 4 of 22
My Home Hub My Services
 Internet:Broadband username:BT Wi-fi Status:BT Access Control:
 Connected
 bthomehub@btbroadband.com
 Active
 Disabled
My Home Network
Devices currently connected to your BT Home Hub:
NetworkDeviceMAC Address IP Address
2.4GHz Wireless:unknown_68:57:2D:5C:7E:6068:57:2D:5C:7E:60192.168.1.112
5GHz Wireless:amazon-23425535240:B4:CD:97:39:7A192.168.1.106
 Steves-MacBookF0:18:98:65:FF:F3192.168.1.91
 Stevens-iPhoneB0:19:C6:BB:85:ED192.168.1.123
Ethernet:No devices detected
USB:No devices detected
1. Product Name: HomeHub5
2. Serial number: +076284+1441000929
3. Firmware version: v0.07.08.11237-BT (Type B) Last updated 23/4/2019
4. Board version: 01
5. WAN: PPP connected
6. Data sent/received: 403.1 MB / 7.7 GB
7. Broadband username: bthomehub@btbroadband.com
8. BT Wi-fi: Yes
9. 2.4GHz wireless network/SSID: BTHub5-3SMP
10. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
11. 2.4GHz wireless security: WPA2 Only (Recommended)
12. 2.4GHz wireless channel: 2
13. 5GHz wireless network/SSID: BTHub5-3SMP
14. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
15. 5GHz wireless security: WPA2 Only (Recommended)
16. 5GHz wireless channel: Automatic (Smart Wireless)
17. Firewall: Default18. MAC Address:
18:83:bf:c8:d4:83
19. Software variant: -
20. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
happysteveo
Message 5 of 22
Thank you both.  I've not managed to replicate the issue via ethernet as it happens so randomly and all of our devices don't have ethernet sockets.
Randomly I saw the HH light go yellow the other day, but before I knew it it went back to blue.  The next time the connection dropped out I check the colour and it was blue.
I dialled 17070 and it was silent between announcements.
Sage
Message 6 of 22
Can you post the hub stats.
HH5- troubleshooting/helpdesk
happysteveo
Message 7 of 22
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request
6. Data sent/received: 423.0 MB / 9.5 GB
8. BT Wi-fi: Yes
18. MAC Address: 18:83:bf:c8:d4:83
happysteveo
Message 8 of 22
Can someone help please?
Message 9 of 22
There are no connection stats showing down/up speed and noise margin  in what you posted
enter your phone number and post results.   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
happysteveo
Message 10 of 22
Our records show the following FTTP network service information for these premises:- Single Dwelling Unit Residential UG Feed with no anticipated issues.
ONT exists with active service. A spare port is available. A new ONT may be ordered.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market A Exchange.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Oct-2013; the Formal Retirement date for IPstream is from 30-Jun-2014.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP Install Process
WBC FTTP
Upto 1000
Upto 220
Available
2 Stage
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 15
12.5 to 17.5
Available
ADSL Max
Up to 8
7 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
U
VRI
N
NTEFaceplate
N
Last Test Date
22-11-2019
