jyyk
Message 1 of 3
Help, fail to replace BT HH3 with Asus RT AC66U
Hi All,
I bought a Asus RT ac66u to replace the HH3.  I can only get the internet working with the Asus RT ac66u but not the BT Vision to work with it.  BT hotline isn't helping either.
I tried to use bthomehub@btbroadband.com as user login and tried both with or without password.  Then when I plug the BT vision to HH3 and it works fine.
I got the VMC011 error message from the BT vision.
Please kindly walk me through step by step if you knew how to solve this problem.
Many thanks.
2 REPLIES 2
AndyCoffin
Message 2 of 3
Re: Help, fail to replace BT HH3 with Asus RT AC66U
a quick search suggests the problem is with the dns servers, try setting it to 8.8.8.8 (googles open dns)
source https://community.bt.com/t5/Other-Broadband-Queries/Using-non-BT-router-TP-Link-WDR3600-with-BT-Visi...
ok different router but if the cause is the same..........
Distinguished Guru
Message 3 of 3
You have to enable multicast on the router to get BT vision to work
If not, I'll try again 🙂
