Gyorgyi
Newbie
Message 1 of 9
Help me set up Smart Hub - basic help needed
Hi everyone, i have a very basic problem, moved into a new build a week ago, received the BT Smart Hub today for Superfast Fibre, got 2 types of cables ( one with yellow, other with red ends) and i feel like i have tried every possible scenario, plugging them into different sockets and whatnot, but just can't seem to get over the flashing orange light on the Hub.
Also the Openreach modem is a Huawei one, i shall try to post pictures, if anyone could be any help, it'd be much appreciated. Clearly this heat is stopping my brain from working.
8 REPLIES 8
Gyorgyi
Newbie
Message 2 of 9
Re: Help me set up Smart Hub - basic help needed
 the Openreach modem
Gyorgyi
Newbie
Message 3 of 9
Bottom of the modem
Gyorgyi
Newbie
Message 4 of 9
The main socket i assume?! I have plugged stuff in the one closest to the TV one
Gyorgyi
Newbie
Message 5 of 9
Back of the Hub 
albertj
Message 6 of 9
Hi @Gyorgyi
Welcome to the Community!
Using the red cable supplied, it needs to go from the port labelled WAN on your Smart Hub into Port 1 of the ONT. Both of which need to be powered.
I wouldn't think those ports on a faceplate in your home would be connected to the install - they may be internal ethernet wiring for you to connect Smart TV's, Set Top Boxes, Laptops etc to.
It should have come with a manual, like this one: https://btsupport.custhelp.com/ci/fattach/get/5259265/1520421203/redirect/1/session/L2F2LzEvdGltZS8x... to help you get connected.
Let me know how you get on 🙂
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Gyorgyi
Newbie
Message 7 of 9
Dear @albertj , thank you very much, it is now solved! Much appreciated!
Have a great evening!
albertj
Message 8 of 9
Great! You too 🙂
Sage
Sage
Message 9 of 9
To get the sockets in the rooms working you need this set up.
