Message 1 of 23
Help please - Fibre broadband dropping out at peak times
My BT fibre was working fine until I had a free speed boost. Now every evening it is dropping out 2-3 times up to 12-15 times a night. The blue light becomes a flashing orange light on my home hub. Any help to resolve this would be appreciated.
Thank you
22 REPLIES 22
Message 2 of 23
Re: Help please - Fibre broadband dropping out at peak times
can you post stats from your router  if hh6 then go to advanced settings then technical log admin
are you using the test socket with a filter to see if that helps by eliminating your internal wiring
try quiet line test  dial 17070 option 2 should be quiet and best with corded phone
Sage
Message 3 of 23
Try a quiet line test 17070 option 2, any noise report a line fault on 151 do not mention broadband. Best with corded phone.
Message 4 of 23
Hi, thanks for quick response. I tried the test socket and line test, no difference and no noise either. I’ll post my hub details shortly just need to get my admin password.
Thanks and I’ll respond soon
Message 5 of 23
My router has been reset since then ooops!
Next time it happens, likely tonight I’ll post the logs. Thanks again
Sage
Message 6 of 23
That won't matter as it's the connection stats we are looking for not the router log.
Message 7 of 23
This is the most recent stuff
15:32:00, 31 Jan.,wl0:Device <34:C0:59:29:A2:7A> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:31:50, 31 Jan.,BR_LAN:The DHCP options that are offered by the device (id:12): DiscoverOptions: 53,55,57,61,51,12 | DiscoverOption55: 1,121,3,6,15,119,252 | RequestOptions: 53,55,57,61,50,51,12 | RequestOption55: 1,121,3,6,15,119,252 | HostName: AdiPad | VendorId:
15:31:50, 31 Jan.,:DHCP Confirmation of Request
15:31:47, 31 Jan.,wl0:A WiFi device <34:C0:59:29:A2:7A> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:30:46, 31 Jan.,:HTTP UserAdmin login from 192.168.1.64 successfully
15:30:17, 31 Jan.,:HTTP UserBasic login from 192.168.1.64 successfully
15:30:15, 31 Jan.,BR_LAN:The DHCP options that are offered by the device (id:1): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,55,57,61,50,51,12 | RequestOption55: 1,121,3,6,15,119,252 | HostName: iPhone | VendorId:
15:30:15, 31 Jan.,:DHCP Confirmation of Request
15:30:12, 31 Jan.,wl0:A WiFi device <6C:72:E7:80:9E:C5> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:26:29, 31 Jan.,ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
15:26:28, 31 Jan.,ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
15:26:28, 31 Jan.,ppp1:TR69 receiving InformResponse message
15:26:27, 31 Jan.,ppp1:TR69 event found : 4 VALUE CHANGE
15:26:26, 31 Jan.,ppp1:TR69 sending Inform message
15:26:24, 31 Jan.,ppp1:TR69 event found : 4 VALUE CHANGE
15:26:23, 31 Jan.,ppp1:TR69 sending Inform message
15:26:21, 31 Jan.,ppp1:TR69 creating new session with ACS
15:25:59, 31 Jan.,:The LAN DHCP Server is active
15:25:59, 31 Jan.,BR_LAN:The DHCP options that are offered by the device (id:37): DiscoverOptions: 53,57,60,12,55 | DiscoverOption55: 1,33,3,6,15,26,28,51,58,59 | RequestOptions: 53,50,57,60,12,55 | RequestOption55: 1,33,3,6,15,26,28,51,58,59 | HostName: amazon-c27bfb43d | VendorId: dhcpcd-5.5.6
15:25:59, 31 Jan.,BR_LAN:The DHCP options that are offered by the device (id:37): DiscoverOptions: 53,57,60,12,55 | DiscoverOption55: 1,33,3,6,15,26,28,51,58,59 | RequestOptions: 53,50,54,57,60,12,55 | RequestOption55: 1,33,3,6,15,26,28,51,58,59 | HostName: amazon-c27bfb43d | VendorId: dhcpcd-5.5.6
15:25:55, 31 Jan.,:DHCP Confirmation of Request
15:25:51, 31 Jan.,:The LAN DHCP Server is inactive
15:25:51, 31 Jan.,wl0:IGMP leave received for group 239.2.0.252 on interface wl0
15:25:51, 31 Jan.,:DHCP Confirmation of Request
15:25:51, 31 Jan.,wl0:IGMP group 239.2.0.252 on interface wl0 ended by 192.168.1.100
15:25:51, 31 Jan.,wl0:IGMP join received for group 239.2.0.252 on interface wl0
15:25:51, 31 Jan.,wl0:IGMP group 239.2.0.252 on interface wl0 started by 192.168.1.100
15:25:51, 31 Jan.,wl0:IGMP group 239.2.0.252 on interface wl0 by 192.168.1.100 requested
15:25:51, 31 Jan.,BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: 53,50,55,12 | DiscoverOption55: 1,3,6,15,12 | RequestOptions: 53,50,55,12 | RequestOption55: 1,3,6,15,12 | HostName: NOW TV Box - 095 | VendorId:
15:25:38, 31 Jan.,:DHCP Confirmation of Request
15:25:38, 31 Jan.,wl0:A WiFi device <34:D2:70:7F:37:9D> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:25:38, 31 Jan.,wl0:Device <34:D2:70:7F:37:9D> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:25:38, 31 Jan.,wl1:A WiFi device <B8:A1:75:15:AF:4C> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
15:25:05, 31 Jan.,wl0:Device <34:D2:70:7F:37:9D> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:25:05, 31 Jan.,wl0:A WiFi device <34:D2:70:7F:37:9D> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:25:05, 31 Jan.,wl0:Device <6C:72:E7:80:9E:C5> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:25:05, 31 Jan.,wl0:Device <B8:A1:75:15:AF:4C> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
15:24:45, 31 Jan.,ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
Message 8 of 23
Again any guidance hugely appreciated thank you
Message 9 of 23
that's the logs looking more for connection stats  this may help  https://community.bt.com/t5/Announcements-Guides-Community/Broadband-Top-Tips-to-get-help-on-the-for...
Sage
Message 10 of 23
What part of we don't want the router logs don't you understand?
I do realise connections can be frustrating but please try to supply the info we need to advise you correctly.
Router stats explained HERE.
