krishna25
Newbie
Message 1 of 3
Help with dropping of my speed BT infinity
Please please help.last 10day my BT Infinity speed drops to 5Mpbs frm 1900hr till mid night.In morning I get 36Mbps and that last till 1900.does any anybody have any clue..
2 REPLIES 2
Message 2 of 3
Re: Help with dropping of my speed BT infinity
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Moderator
Moderator
Message 3 of 3
Hi @krishna25 and welcome.
It sounds like you have a congestion problem so post the details @imjolly has asked for and we'll take a look. If you can run the further diagnostics on the speed tester it'll write back to wholesales servers so we'll have a record of the problem.
Cheers
David
