mrt1981
Message 11 of 21
Re: Here I am again... Constant disconnects...
Thanks @NeilO , pm sent
Moderator
Moderator
Message 12 of 21
Hi @mrt1981,
Thanks for sending in the account information.
I have arranged for an engineer to check the network as I am finding a possible network fault. This work is due to be completed by 10/10/2019 and I will follow up with you after this date.
I have also sent you a private message.
Matt
mrt1981
Message 13 of 21
Thanks @Matt-S, much appreciated
Moderator
Moderator
Message 14 of 21
Hi @mrt1981,
Openreach have advised that they have fixed the fault which was found on the network.
Can you test the connection over the weekend just to make sure the fault we found was the route cause of the problem?
Matt
mrt1981
Message 15 of 21
Hey @Matt-S, will do. I can't say I've noticed any disconnects in the last few days but I've been out a fair bit, so I'll check the logs keep an eye out over the weekend.
mrt1981
Message 16 of 21
Hi @Matt-S, so everything appeared to be fine for about a week, no disconnects and good speed, until last night around 10.30pm the connection dropped a number of times and my speed has been much slower since then (although somehow the speed test says it’s as expected?)
WAN logs below:
22:58:12, 12 Oct.,:WAN: SENSING AUTO VDSL
22:57:38, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:57:38, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:57:38, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:57:37, 12 Oct.,dsl:VDSL link Up: Down Rate=16677Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:57:16, 12 Oct.,:VLAN VLAN_DATA disconnected
22:57:12, 12 Oct.,dsl:VDSL Link Down: duration was 699 seconds
22:46:10, 12 Oct.,:WAN: SENSING AUTO VDSL
22:45:33, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:45:33, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:45:33, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:45:33, 12 Oct.,dsl:VDSL link Up: Down Rate=15232Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:45:10, 12 Oct.,:VLAN VLAN_DATA disconnected
22:45:08, 12 Oct.,dsl:VDSL Link Down: duration was 37 seconds
22:44:31, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:44:31, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:44:31, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:44:31, 12 Oct.,dsl:VDSL link Up: Down Rate=15623Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:44:10, 12 Oct.,:VLAN VLAN_DATA disconnected
22:44:06, 12 Oct.,dsl:VDSL Link Down: duration was 172 seconds
22:41:50, 12 Oct.,:WAN: SENSING AUTO VDSL
22:41:14, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:41:14, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:41:14, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:41:14, 12 Oct.,dsl:VDSL link Up: Down Rate=42023Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:40:50, 12 Oct.,:VLAN VLAN_DATA disconnected
22:40:48, 12 Oct.,dsl:VDSL Link Down: duration was 21 seconds
22:40:27, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:40:27, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:40:27, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:40:27, 12 Oct.,dsl:VDSL link Up: Down Rate=14000Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:40:04, 12 Oct.,:VLAN VLAN_DATA disconnected
22:40:02, 12 Oct.,dsl:VDSL Link Down: duration was 29 seconds
22:39:33, 12 Oct.,ptm0.101:VLAN VLAN_DATA connected
22:39:33, 12 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:39:33, 12 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:39:33, 12 Oct.,dsl:VDSL link Up: Down Rate=12687Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
22:39:12, 12 Oct.,:VLAN VLAN_DATA disconnected
22:39:08, 12 Oct.,dsl:VDSL Link Down: duration was 694144 seconds
00:01:50, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:12, 01 Jan.,ptm0.101:VLAN VLAN_DATA connected
00:01:11, 01 Jan.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:11, 01 Jan.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:11, 01 Jan.,dsl:VDSL link Up: Down Rate=45124Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:24, 01 Jan.,:WAN: ethernet as LAN
08:32:03, 04 Oct.,:WAN: SENSING AUTO VDSL
08:31:29, 04 Oct.,ptm0.101:VLAN VLAN_DATA connected
08:31:29, 04 Oct.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
08:31:29, 04 Oct.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
08:31:28, 04 Oct.,dsl:VDSL link Up: Down Rate=44462Kbps, Up Rate=9998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
08:31:07, 04 Oct.,:VLAN VLAN_DATA disconnected
08:31:03, 04 Oct.,dsl:VDSL Link Down: duration was 32840 seconds
mrt1981
Message 17 of 21
Product name:
BT Hub 6A
Serial number:
+084316+NQ64506849
Firmware version:
SG4B1000E01E
Firmware updated:
06-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 16 Hours 7 Minutes 22 Seconds
Data rate:
10.00 Mbps / 17.43 Mbps
Maximum data rate:
14786 / 31371
Noise margin:
10.8 dB / 15.2 dB
Line attenuation:
22.2 dB
Signal attenuation:
0 dB / 22.2 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
282 MB Uploaded / 3391 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-9GW7
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-9GW7
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:60:C7:B7
Software variant:
Boot loader:
7.33.1
Sage
Sage
Message 18 of 21
Check for noise on your line. 17070 option 2, best with corded phone.
mrt1981
Message 19 of 21
Quiet line test is silent
Moderator
Moderator
Message 20 of 21
Hi @mrt1981  sorry that connection has started to drop again. I'll let @Matt-S  know and he will check on it when he is back in the office.
cheers
John
