chipp
Message 1 of 7
Hi Latency/Poor Speed
Hi i was hoping an admin could look into my infinity speeds please i seem to have really high latency on the line i have run the BT speed test wired and the ping seems really high, if i play online games they just seem to lag out. I am currently trying to download a 500mb file and its telling me its going to take 8 hours,
I have also got 1 - 12 off the trouble shooting hub if thats any use and if any other info is required please let me know and i will provide, Thanks
1. Product Name: HomeHub5
2. Serial number: +076286+1606001780
3. Firmware version: v0.07.06.09028-BT (Type B) Last updated 8/11/2016
4. Board version: 01A
5. VDSL uptime: 7 days, 11:18:36
6. Data Rate: 20000 / 79987
7. Maximum Data Rate: 30096 / 84521
8. Noise Margin: 13.0 / 7.3
9. Line Attenuation: 12.7 / 13.1
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 5.1 GB / 171.6 GB
12. Broadband username: bthomehub@btbroadband.com
6 REPLIES 6
chipp
Message 2 of 7
Re: Hi Latency/Poor Speed
Oh also forgot to mention i have BT TV and trying to use the BT player on the box seems to have really slowed down as well  i keep getting connection issues then when it does load i get loads of missing images before it finally catches up after a minute or so
chipp
Message 3 of 7
bumpty bump bump de bumpty bump
Message 4 of 7
There's nothing wrong with your speeds, you are syncing at the maximum for Infinity2. Nobody can do anything about the latency. Are you connecting wired or wireless.
chipp
Message 5 of 7
Wired and a ping of 200 seems very excessive for infinity 2 what could be causing it do you know? Thx for the reply so far
stevebrass
Expert
Message 6 of 7
When you say wired do you mean direct ethernet from home hub to computer or via a switch/powerline adapters?
Sage
Message 7 of 7
Post a result of a tracert tobbc.co.uk.
