Newbie
Message 1 of 13
High noise margin
Hello, Ive been with BT for the last 2 years. My son is online gamer and since the 22/12/16 hes been complaining about connection issues causing his game to 'lag out'/connection loss, inconsistant download speeds causing slow browsing/downloading times. Ive been looking into it since untill I came across the high noise margin which apparently shouldnt be so high. Ive read up and ive left the router uptime for 3 days minimum. Ive tried the quiet line test which seemed totally fine with no fuzziness or crackling noises. I currently have the HH5, running weird upto my sons room straight into his pc. Would anyone be able to help me?
1. Product name: BT Home Hub
2. Serial number: +068543+NQ43439441
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 02/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 3 days, 19:59:35
6. Data rate: 9999 / 54935
7. Maximum data rate: 27939 / 82614
8. Noise margin: 22.7 / 13.6
9. Line attenuation: 13.9 / 12.3
10. Signal attenuation: 14.7 / 12.3
11. Data sent/received: 2.6 GB / 62.6 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-X7KM
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-X7KM 5GHz
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
12 REPLIES 12
Message 2 of 13
Re: High noise margin
Welcome to this user forum.
Are you on Infinity 1 or Infinity 2 as your line is capable of 82Mbs, but Infinity 1 is restricted to 55Mbs, which is why there is a high noise margin, as there it lots of spare capacity.
Is the PC connected using an Ethernet cable?
Newbie
Message 3 of 13
Thanks for the reply Keith, im currently paying for Infinity1 but i have been getting speeds greater than 55Mbps. Yes my sons pc is connected via ethernet cable.
Tags (1)
Message 4 of 13
You are getting the maximum connection speed for infinity 1 there is no way that you can have a faster speed unless you moved to infinity 2
Newbie
Message 5 of 13
I havent got a problem with the download speed, its the inconsistency of the internet were recieving at the moment, my sons having problems having had new games for christmas that he cant play online, ive moved his pc and xbox downstairs next to the router and the problem still persists. Ive monitered ping and it seems to jump every so often but youve got to catch it at the right time. Ive tried disconnecting everything wirelessly and reconnecting them one by one incase any of the devices are interfearing but the problem still persists with the xbox/computer only connected.
Message 6 of 13
You are best to connect by Ethernet for gaming. Wireless can be affected by wireless interference, and it is not necessarily from interference from other connected devices.
Message 7 of 13
can you post a tracert to bbc.co.uk and anther to one of your sons games servers
Message 8 of 13
Could you please post the results from the BT Wholesale speed checker, including the further diagnostics.
This must be done with a computer connected to the home hub using an Ethernet cable.
Newbie
Message 9 of 13
>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.246.78]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms BThomehub.home [192.168.1.254]
2 * * * Request timed out.
3 * * 11 ms 31.55.187.181
4 13 ms 12 ms 13 ms 31.55.187.188
5 12 ms 13 ms 13 ms 195.99.127.220
6 11 ms 12 ms 11 ms 62.172.103.197
7 12 ms 12 ms 12 ms 195.99.126.101
8 * * * Request timed out.
9 14 ms 13 ms 13 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10 13 ms 13 ms 13 ms 132.185.255.165
11 14 ms 14 ms 14 ms 212.58.246.78
Trace complete.
>tracert oldschool66.runescape.com
Tracing route to l3uklo11-bond0-16.jagex.com [217.163.53.213]
3 * 11 ms 11 ms 31.55.187.181
4 13 ms 14 ms 12 ms 31.55.187.188
5 11 ms 11 ms 12 ms core1-hu0-17-0-5.southbank.ukcore.bt.net [195.99
.127.182]
6 13 ms 14 ms 14 ms vhsaccess1-pos2-0.faraday.fixed.bt.net [195.99.1
27.5]
7 13 ms 13 ms 13 ms t2c4-et-3-1-0-0.uk-lon1.eu.bt.net [166.49.211.24
4]
8 12 ms 12 ms 12 ms 5-2-1.ear2.London15.Level3.net [212.187.173.89]
9 12 ms 12 ms 13 ms ae-127-3513.edge6.London1.Level3.net [4.69.166.6
5]
10 14 ms 14 ms 16 ms 195.50.118.22
11 12 ms 13 ms 12 ms oldschool66.runescape.com [217.163.53.213]
Trace complete.
Newbie
Message 10 of 13
Download Speed (Mbps): 48.88
Upload Speed (Mbps): 8.98
Ping Latency(ms): 20.88
1. Best Effort Test: -provides background information.
Download Speed
48.88 Mbps
0 Mbps 53.17 Mbps
Max Achievable Speed
Download speedachieved during the test was - 48.88 Mbps
For your connection, the acceptable range of speedsis 27.5 Mbps-53.17 Mbps .
Additional Information:
IP Profile for your line is - 53.17 Mbps
2. Upstream Test: -provides background information.
Upload Speed
8.98 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 8.98Mbps
Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
