helenmac1cat
Message 1 of 4
High ping to all servers
This time i'm not sure what the issue is but I have a high ping to all servers I ping or tracert to.
For an example, here's one to the BBC site.
Tracing route to bbc.co.uk [212.58.244.20]
over a maximum of 30 hops:
  1     2 ms     3 ms     2 ms  BTHUB5 [192.168.1.254]
  2    52 ms    52 ms    52 ms  217.32.147.8
  3    57 ms    56 ms    51 ms  217.32.147.78
  4    40 ms    42 ms    44 ms  213.120.176.34
  5    54 ms    55 ms    55 ms  217.41.168.151
  6    47 ms    49 ms    48 ms  217.41.168.109
  7    42 ms    44 ms    45 ms  acc2-10GigE-0-7-0-5.l-far.21cn-ipp.bt.net [109.1
59.249.206]
  8    47 ms    47 ms    48 ms  core3-te0-9-0-21.faraday.ukcore.bt.net [109.159.
249.165]
  9    53 ms    53 ms    54 ms  peer2-xe8-0-0.telehouse.ukcore.bt.net [109.159.2
54.177]
 10    56 ms    55 ms    44 ms  194.74.65.42
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13    55 ms    55 ms    54 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 14    58 ms    55 ms    55 ms  132.185.255.149
 15    47 ms    48 ms    47 ms  fmt-vip71.telhc.bbc.co.uk [212.58.244.20]
Trace complete.
 Any ideas what the problem is?
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: High ping to all servers
Is that traceroute done over a wired connection or wireless?
Do you have a Homehub 5?
If not, I'll try again 🙂
helenmac1cat
Message 3 of 4
I am doing it over wireless and I do have the HH5.
Distinguished Guru
Message 4 of 4
It's almost pointless doing ping tests over a wireless connection as wireless interference can never be ruled out.
Are you using a 5GHz connection as that is far less prone to interference than 2.4GHz? Wireless-AC is even better.
But nothing is better than a wired connection for reducing latency.
