Message 1 of 7
High signal noise ratio and connection drop outs
Having a problem with FTTC broadband (BT Infinity) for the past few days. Connection keeps dropping out. Quick check of the event log shows 10 or more connection loses in the past 24 hours. It looks like the signal noise ratio is high. Here is an example below...
21:07:45, 22 Dec.(94473.950000) PPPoE is up -​ Down Rate=66918Kbps, Up Rate=18169Kbps; SNR Margin Down=10.3dB, Up=9.2dB
Can a mod connect with me to see if we can get this resolved?
6 REPLIES 6
Message 2 of 7
Re: High signal noise ratio and connection drop outs
Quiet line test shows a quiet line no noise. BTHH5 router.
Message 3 of 7
the high noise margin is the result of your drops in connection not the cause of them
post stats from the hh5  troubleshooting then helpdesk
try connecting to test socket with a filter and see if that improves your stability
Message 4 of 7
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51533319
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 30/06/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:04:17
6. Data rate:18169 / 66918
7. Maximum data rate:23229 / 81229
8. Noise margin:8.1 / 9.9
9. Line attenuation:19.2 / 16.9
10. Signal attenuation:19.0 / 16.9
11. Data sent/received:242.1 MB / 1.4 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:Redacted
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:Redacted
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:Redacted
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Here are the line stats.
Plugged into master socket (not test socket) but no other devices / extenstions connected.
Message 5 of 7
You should try the test socket as that should be your best connect and eliminates any problems caused by your internal wiring and also a faulty faceplate. This will show if stability problem continues that not in your home and avoid the call out fee of £85
your connection time is only 4 min is that due to manual reset?
Message 6 of 7
Yep manual reset due to plugging into the test socket as you suggested. The connection stats were comparable on the master socket and test socket. The connection had held for 12 hours before this. Had auto reset several times last night and early this morning.
Could it be a temporary issue has triggered the exchange to re-validate the connection?
Message 7 of 7
Due to the previous drops in connection you mentioned I did not expect to see any improvement in the stats but by connecting to test socket and leaving it connected to see if that solved the stability problem
the post said you were connected to the master not test socket
with FTTC  it the cabinet and it sounds more like connection problem not a re-validate of your connection
the high noise margin suggests there have been quite a few drops in connection and maybe a rew manual resets to try and fix speed
