nowty
Message 1 of 4
Home Hub 2 upgrade to Home Hub3 - Infinity 2 speed drops to infinity 1 speed
I have had infinity 2 for the past couple of years and had been having typical speeds of approx 50M+ DOWN and 15M+ UP.
Then about 1 month ago I upgraded to a home hub 5, I paid for it online as I did not want to be tied into another contract. From day 1 with this my speed seems to have been reset to infinity 1 speeds, i.e. 37 DOWN and 10 UP.
OK still pretty reasonable but the point is I am paying for infinity 2 and only getting an infinity 1 service.
I have read a number of threads on this forum which seem to suggest that this is a known problem when upgrading to home hub 5 online which I did and a suggestion is to contact a moderator to fix this.
I tried this but then I received a PM saying that I could not do this via a PM, hence this posting.
3 REPLIES 3
Message 2 of 4
Re: Home Hub 2 upgrade to Home Hub3 - Infinity 2 speed drops to infinity 1 speed
It is a known problem.
The moderators have been informed of your problem. Once they have read this they may be able to help. They are a BT UK based team and if they can help they will reply via this post.
Moderator
Moderator
Message 3 of 4
Hi Nowty,
Welcome to the community forum. I'll be able to get this sorted, please send me in your details using the "Contact Us" link found in my profile.
PaddyB
nowty
Message 4 of 4
Cheers, all up to infinity 2 speeds again.
But of course should not have dropped in the first place.
