Aleksis
Newbie
Message 1 of 3
Home Hub 5 Constantly Restarting
Hi, my Home Hub 5 is restarting constantly every 25 seconds,
The logs:
00:03:32, 01 Jan.DSL Link Down: duration was 25 seconds
00:03:15, 01 Jan.Device Connected: 192.168.1.223, d0:73:d5:01:d4:1d, LIFX Bulb
00:03:14, 01 Jan.2.4G Client associate from d0:73:d5:01:d4:1d (IP=192.168.1.223) RSSI=-29, Rate=65Mbps, host LIFX Bulb
00:03:12, 01 Jan.Receive a DHCP request
00:03:09, 01 Jan.DSL Link Up: Down Rate=61281Kbps, Up Rate=11678Kbps; SNR Margin Down=3.2dB, Up=6.1dB
As you can see it gets a connection but then goes down after a short period of time, it keeps doing this over and over again and the internet simply does not work, here are my helpdesk info's:
1. Product Name: HomeHub5
2. Serial number: +076284+1451000119
3. Firmware version: v0.07.07.03230-BT (Type B) Last updated 12/5/2018
4. Board version: 01
5. VDSL uptime: -
6. Data Rate: -
7. Maximum Data Rate: 11700 / 62399
8. Noise Margin: 6.1 / 3.3
9. Line Attenuation: 28.5 / 21.1
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: -
12. Broadband username: bthomehub@btbroadband.com
Help would be appriciated, I've ensured the cables are connected properly.
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Home Hub 5 Constantly Restarting
Any noise on your line? 17070 option 2, best with corded phone.
Aleksis
Newbie
Message 3 of 3
Currently don't have a landline phone I could check this with as I only use the line for internet, I'll see if I can get one tomorrow.
