Gazza02
Message 1 of 5
Home Hub 5 Disconnecting
For the last 2 days the Home Hub 5 has started dropping connection at night the first time the hub started flashing green and then was followed by a orange light, once the blue light came back on I checked the hub stats and it still showed 13 days connection time.
Then during the day yesterday open RG made it go down for reboot around 2 and then last night it seems like it dropped again with the following:
05:42:15, 20 May. ( 16.390000) Boot reason: watchdog reset
At the moment speed does not seem to be affected but I am wondering if the home hub may be faulty? if so will a mod be able to help me?
First disconnect:
00:15:52, 19 May. (1159883.940000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:15:50, 19 May. (1159881.640000) WAN operating mode is VDSL
00:15:50, 19 May. (1159881.640000) Last WAN operating mode was VDSL
00:15:48, 19 May. (1159879.940000) PPP IPCP Receive Configuration ACK
00:15:48, 19 May. (1159879.920000) PPP IPCP Send Configuration Request
00:15:48, 19 May. (1159879.920000) PPP IPCP Receive Configuration NAK
00:15:48, 19 May. (1159879.920000) PPP IPCP Send Configuration ACK
00:15:48, 19 May. (1159879.920000) PPP IPCP Receive Configuration Request
00:15:48, 19 May. (1159879.900000) PPP IPCP Send Configuration Request
00:15:47, 19 May. (1159878.440000) PPPoE is up -​ Down Rate=76777000Kbps, Up Rate=19999000Kbps; SNR Margin Down=10.3dB, Up=9.9dB
00:15:47, 19 May. (1159878.420000) CHAP authentication successful
00:15:46, 19 May. (1159878.270000) CHAP Receive Challenge
00:15:46, 19 May. (1159878.270000) Starting CHAP authentication with peer
00:15:46, 19 May. (1159878.260000) PPP LCP Receive Configuration ACK
00:15:46, 19 May. (1159878.250000) PPP LCP Send Configuration Request
00:15:46, 19 May. (1159878.250000) PPP LCP Receive Configuration Reject
00:15:46, 19 May. (1159878.240000) PPP LCP Send Configuration ACK
00:15:46, 19 May. (1159878.240000) PPP LCP Receive Configuration Request
00:15:46, 19 May. (1159878.240000) PPP LCP Send Configuration Request
00:13:44, 19 May. (1159755.600000) Admin login successful by 192.168.1.85 on HTTP
00:13:39, 19 May. (1159750.640000) Admin login FAILED by 192.168.1.85 on HTTP
00:13:39, 19 May. (1159750.640000) New GUI session from IP 192.168.1.85
00:12:44, 19 May. (1159696.080000) CWMP: session closed due to error: No response
00:12:44, 19 May. (1159696.060000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:12:44, 19 May. (1159696.060000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:12:14, 19 May. (1159665.640000) CWMP: session closed due to error: No response
00:12:14, 19 May. (1159665.630000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:12:14, 19 May. (1159665.620000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:12:13, 19 May. (1159665.210000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
00:12:13, 19 May. (1159664.520000) PPPoE is down after 19325 minutes uptime [Disconnected]
00:12:10, 19 May. (1159661.880000) PPP LCP Send Termination Request [Peer not responding]
Second disonnect:
14:34:10, 19 May. ( 41.260000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
14:34:10, 19 May. ( 41.260000) Wire Lan Port 4 up
14:34:10, 19 May. ( 41.260000) Wire Lan Port 2 up
14:34:09, 19 May. ( 40.500000) WAN Auto-​sensing running.
14:34:04, 19 May. ( 35.640000) System up, firmware version: 4.7.5.1.83.8.204 (Type A)
14:33:56, 19 May. ( 27.550000) WPA2 mode selected
14:33:56, 19 May. ( 27.550000) WPS enabled
14:33:53, 19 May. ( 24.930000) WPA2 mode selected
14:33:53, 19 May. ( 24.930000) WPS enabled
14:33:44, 19 May. ( 15.720000) System start
14:33:13, 19 May. (1211325.120000) PPP LCP Send Termination Request [User request]
14:33:12, 19 May. (1211323.180000) The system is going DOWN for reboot.
14:33:12, 19 May. (1211323.180000) OpenRG is going for reboot by IPC command
14:33:07, 19 May. (1211318.180000) OpenRG will go down for reboot in 5 seconds
Then last night:
05:42:44, 20 May. ( 45.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
05:42:44, 20 May. ( 45.220000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
05:42:43, 20 May. ( 44.650000) CWMP: Initializing transaction for event code 1 BOOT
05:42:41, 20 May. ( 42.160000) WiFi auto selected channel 40
05:42:41, 20 May. ( 42.160000) 36-​93::40-​94::44-​93::48-​92::52-​92::56-​92::60-​92::64-​90::100-​92::104-​92::108-​93::112-​93::116-​94::120-​95::124-​94::128-​95
05:42:41, 20 May. ( 42.150000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
05:42:41, 20 May. ( 42.150000) WiFi auto selected channel 11
05:42:41, 20 May. ( 42.150000) 1-​96::2-​96::3-​96::4-​94::5-​96::6-​96::7-​97::8-​97::9-​96::10-​97::11-​98::12-​96::13-​97
05:42:41, 20 May. ( 42.150000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
05:42:41, 20 May. ( 42.140000) Wire Lan Port 4 up
05:42:41, 20 May. ( 42.140000) Wire Lan Port 2 up
05:42:40, 20 May. ( 41.390000) WAN Auto-​sensing running.
05:42:35, 20 May. ( 36.480000) System up, firmware version: 4.7.5.1.83.8.204 (Type A)
05:42:27, 20 May. ( 28.150000) WPA2 mode selected
05:42:27, 20 May. ( 28.150000) WPS enabled
05:42:24, 20 May. ( 25.570000) WPA2 mode selected
05:42:24, 20 May. ( 25.570000) WPS enabled
05:42:15, 20 May. ( 16.390000) System start
4 REPLIES 4
Gazza02
Message 2 of 5
Re: Home Hub 5 Disconnecting
Here is the stat page, as I said it has not lowered the speed yet:
1. Product name: BT Home Hub
2. Serial number: +076272+NQ33595271
3. Firmware version: Software version 4.7.5.1.83.8.204 (Type A) Last updated 13/01/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 04:32:20
6. Data rate: 19999 / 76777
7. Maximum data rate: 30680 / 92667
8. Noise margin: 10.0 / 10.0
9. Line attenuation: 16.7 / 14.8
10. Signal attenuation: 16.6 / 14.8
11. Data sent/received: 47.0 MB / 214.6 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID: BTHub5-3XCF
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-3XCF5G
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 18:62:2c:07:60:36
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
rarmitage124
Recognised Expert
Message 3 of 5
Have you tried a factory reset of the hub?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Gazza02
Message 4 of 5
Yep reset the hub this morning 🙂
I am wondering since our contract is coming to an end early July and we had had BT call us about renewing (we have not renewed yet) if we would be able to get a replacement hub from them if we do renew?
I will keep this thread updated but something doesnt seem right, we have had a really good solid connection for the last few months, I am really hoping DLM does not kick in 😕
Message 5 of 5
yo will not get a replacement automatically at renewal but you could try making it a condition of renewal  you may be asked to pay the £6.95 postage though.  practice your negotiating skills and prepare with other current offers
