Sage
Sage
Message 11 of 21
Re: Home Hub 5 and dropped connections
If you still have the ECI modem and HH3 then it's easy to prove your point.
Dave123
Message 12 of 21
Hi, I have the same issue with the HH5 disconnecting randomly for no apparent reason.  I put the old ECI modem and HH3 back in place and found the line was far more stable with no disconnects.
Dave
Storm
Expert
Message 13 of 21
I've only been using the HH5 for around a month or so and my ECI modem and HH3 could hold the connection for over 2 months without an IP change at all.
Storm
Expert
Message 14 of 21
And again today:-
16:49:25, 15 Dec.(518430.370000) CWMP: session completed successfully
16:49:25, 15 Dec.(518430.150000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
16:49:23, 15 Dec.(518428.440000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:49:23, 15 Dec.(518428.430000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
16:49:23, 15 Dec.(518428.240000) CWMP: Initializing transaction for event code 2 PERIODIC
16:49:05, 15 Dec.(518410.160000) CWMP: session completed successfully
16:49:05, 15 Dec.(518409.930000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
16:49:00, 15 Dec.(518405.140000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:49:00, 15 Dec.(518405.130000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:48:57, 15 Dec.(518402.580000) WAN operating mode is VDSL
16:48:57, 15 Dec.(518402.580000) Last WAN operating mode was VDSL
16:48:56, 15 Dec.(518401.650000) PPP IPCP Receive Configuration ACK
16:48:56, 15 Dec.(518401.640000) PPP IPCP Send Configuration Request
16:48:56, 15 Dec.(518401.630000) PPP IPCP Receive Configuration NAK
16:48:56, 15 Dec.(518401.620000) PPP IPCP Send Configuration ACK
16:48:56, 15 Dec.(518401.620000) PPP IPCP Receive Configuration Request
16:48:56, 15 Dec.(518401.620000) PPP IPCP Send Configuration Request
16:48:56, 15 Dec.(518401.620000) CHAP authentication successful
16:48:56, 15 Dec.(518401.560000) CHAP Receive Challenge
16:48:56, 15 Dec.(518401.560000) Starting CHAP authentication with peer
16:48:56, 15 Dec.(518401.560000) PPP LCP Receive Configuration ACK
16:48:56, 15 Dec.(518401.540000) PPP LCP Send Configuration Request
16:48:56, 15 Dec.(518401.540000) PPP LCP Receive Configuration Reject
16:48:56, 15 Dec.(518401.540000) PPP LCP Send Configuration ACK
16:48:56, 15 Dec.(518401.540000) PPP LCP Receive Configuration Request
16:48:56, 15 Dec.(518401.530000) PPP LCP Send Configuration Request
16:48:55, 15 Dec.(518399.970000) CWMP: session closed due to error: Could not resolve host
16:48:55, 15 Dec.(518399.950000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:48:55, 15 Dec.(518399.940000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:48:54, 15 Dec.(518399.750000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
16:48:48, 15 Dec.
(518392.880000) PPP LCP Send Termination Request [User request]
Can anyone tell me what this means? I've tried BT Chat again and they just refuse to answer what this all means
Distinguished Expert
Message 15 of 21
Those firewall entries relate to remote administration of your modem and internet connection. The server URL is for motive.com who BT use for remote administration.
To say thanks for a helpful answer, please click the white star
Storm
Expert
Message 16 of 21
Thanks for the response, any idea why they are causing me to lose my ip address every time?
souloo
Message 17 of 21
Hello i have same problem , i know the topic is old , but did some 1  found  any solution for this ? i get quite annoyed by losing the connection everyday .
Message 18 of 21
EDIT: I see that you have already posted your problem https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/slower-Broadband-after-moving-home/td-p/1271...
and are being helped by a moderator. You would be better to wait for their assistance rather than double posting about the problem.
souloo
Message 19 of 21
i got infinity for 2 weeks now , my old speed problems got sorted already , now i am just suffering with hh5 disconnections , everyday at diffrent hours  got this :
16:33:45, 15 Jun.(862429.690000) CWMP: session completed successfully
16:33:45, 15 Jun.(862429.470000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
16:33:39, 15 Jun.(862424.050000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:33:39, 15 Jun.(862424.050000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:33:37, 15 Jun.(862421.250000) WAN operating mode is VDSL
16:33:37, 15 Jun.(862421.250000) Last WAN operating mode was VDSL
16:33:36, 15 Jun.(862420.340000) PPP IPCP Receive Configuration ACK
16:33:36, 15 Jun.(862420.340000) PPP IPCP Send Configuration Request
16:33:36, 15 Jun.(862420.330000) PPP IPCP Receive Configuration NAK
16:33:36, 15 Jun.(862420.330000) PPP IPCP Send Configuration ACK
16:33:36, 15 Jun.(862420.330000) PPP IPCP Receive Configuration Request
16:33:36, 15 Jun.(862420.330000) PPP IPCP Send Configuration Request
16:33:36, 15 Jun.(862420.330000) CHAP authentication successful
16:33:35, 15 Jun.(862419.990000) CHAP Receive Challenge
16:33:35, 15 Jun.(862419.990000) Starting CHAP authentication with peer
16:33:35, 15 Jun.(862419.990000) PPP LCP Receive Configuration ACK
16:33:35, 15 Jun.(862419.980000) PPP LCP Send Configuration Request
and after this my internet  got disconnected .
pwwhitehead
Message 20 of 21
I had the same issue for 5 months, Two opreach visits they could fing no errors on my line. HH5 replaced even worse than current hub, so sent replacement back and used original hub. All this reduced my speed profile, in the end got fed up and went back to Openreach router and used HH5 as router. Result rock solid connection for over two weeks then a re- connection and profile has started to increase. Sorry but bt HH5 is not fit for purpose and BT should either admit the issue and fix with firmware update or remove it for sale!!
