hcharge
Message 1 of 13
Home Hub 5 problems with other router connected.
So here's a bit of a strange one...
I've had the HH5 connected as just a simple router (disabled both WiFi radios 2.4 and 5GHz) for about 4 or 5 months, with the HH5 plugged into my DIR-655 which I use for WiFi. Randomly on Friday my internet connection stopped working, even the devices plugged in via Ethernet stopped working, and the HH5 kept doing its light cycle Orange, Green, Blue etc.
I rang customer support and was on the phone for 45 minutes or so until she said that she could see a fault on the line. So I just took her word for it and waited for an engineer to come. Except the day before he came, I thought I would just try disconnecting my router and switching the HH5's WiFi back on. And the internet connection magically came back to life! I cancelled the engineer and left the setup like this for a few days. Last night I tried putting it back to how the setup was before the problem started, and haven't had any problems so far.
Has anybody experienced anything similar? Is there some sort of "calling home" that the HH5 does? I presume there's no problem in me not using their router for WiFi!?
12 REPLIES 12
Distinguished Guru
Message 2 of 13
Re: Home Hub 5 problems with other router connected.
A quick fix is to turn the wireless on the Homehub ON.
If not, I'll try again 🙂
hcharge
Message 3 of 13
So does this just need to be done every so often? And OK to turn it off afterwards?
Distinguished Guru
Message 4 of 13
When would you do it every so often?
Why would you turn it off?
hcharge
Message 5 of 13
Because the router isn't in an ideal position in my flat, and I have concrete walls. So I have had to run an ethernet cable to my router which I have in the middle of the flat which provides the WiFi. It would be OK if the modem wasn't inside the HH5, but I'm stuck with it.
Distinguished Guru
Message 6 of 13
But if turning it on is a fix, why would you turn it off and break it again? You don't have to use it, just have it on.
hcharge
Message 7 of 13
Because it affects the other routers WiFi. I guess I could set it to a different channel and different SSID? Just seems stupid that the router has to have WiFi enabled to function properly, it's bad enough I have to use it at all.
Message 8 of 13
You don't have to use it. You can either use an Openreach modem and your own router or a third party VDSLmodem/router.
hcharge
Message 9 of 13
Doesn't that affect using YouView for certain channels? And would I have to buy an OpenReach modem?
Distinguished Guru
Message 10 of 13
That's right, but it's because the firmware is now broken by the latest update and turning on the wireless is a fix.
It's not perfect, but it's better than having the Homehub rebooting all the time.
