colemant
Message 1 of 11
Home Hub 5 slows down every day and needs a reset
I don't get disconnected, but almost each day my connection degrades to 7mb from 71mb when I've reset it.  The hub is in the same room, it is wirelss, but about 9 metres from the hub with nothing in the middle (walls etc) to interfere.
Speedtest
 1. Product Name: HomeHub5
2. Serial number: +076284+1430013362
3. Firmware version: v0.07.03.0814-BT (Type B) Last updated 3/12/2014
4. Board version: 01
5. VDSL uptime: 0 days, 12:18:34
6. Data Rate: 20000 / 77091
7. Maximum Data Rate: 20668 / 92718
8. Noise Margin: 6.2 / 6.3
9. Line Attenuation: 0.0 / 17.4
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 305.9 MB / 1.1 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-MPNR
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-MPNR
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: 40
22. Firewall: Default
23. MAC Address: 18:83:bf:64:64:7a
24. Software variant: -
25. Boot loader: 0.4.3-BT (Fri May 30 23:34:17 2014)
10 REPLIES 10
Message 2 of 11
Re: Home Hub 5 slows down every day and needs a reset
if your hub does not disconnected from the internet then iis this a wireless problem with your hub
you need to give move details - hub stats and btspeedtester diagnostic results
colemant
Message 3 of 11
Have reset the router and now have the following for comparison
5. VDSL uptime: 0 days, 00:03:21
6. Data Rate: 20000 / 77143
7. Maximum Data Rate: 20729 / 92768
8. Noise Margin: 6.1 / 6.3
11. Data sent/received: 1.6 MB / 36.9 MB
13. BT Wi-fi: Yes
gvi
Message 4 of 11
I have the same issue but my connection will drop also I have had speeds as low as 200kbps (that's right kbps!!!) On a supposedly 78mb infinity package and now I have connected with a wire and still have the same issue!!! Any ideas?
gvi
Message 5 of 11
P.s where do I stand on canceling my contract as this is not the service I was promised or is advised and have never received a good service?
Message 6 of 11
you stats are almost identical
so this is wireless problem not an internet conenction problem
have you turned off smart setup  http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
then split the networks as many devices do not like the 2 networks sync together  http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
you can also select your own channel rather than automatic
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
inssider3.1.2.1
Message 7 of 11
@gvi
start your own subject and post the router stats and btspeedtester diagnostic test results - must be done wired not wireless
if your download speed problem is when using wireless but ok when wired then your internet conenction is ok
colemant
Message 8 of 11
thanks, done all that, lets see over the next couple of days.
colemant
Message 9 of 11
thanks for this, now gone 3 days since having to reset, which is longer than any previous time.  I guess successful.
Many thanks
horsemanuk
Newbie
Message 10 of 11
The reply from
