Message 1 of 2
Home Hub5 Issues
hello all
so for the 3 rd day running my router ( BT home hub 5 ) has dropped its connection and the lights go
1. Constant Green
2. Blue
3. Orange
4. Flashing orange B symbol
5. Blue
6. Can reconnect to the internet
I powered down the home hub and removed all cables, reseated them and powered back up.
before I try to log a call and get stuck in the loop of there is nothing wrong,  does anyone have anything I can try?
1 REPLY 1
Message 2 of 2
Re: Home Hub5 Issues
You could try a factory reset by pressing the recessed button in the rear with a pin for about 20 seconds until the lights flash. If you are getting a green light, it is a hub problem rather than a line/connection problem.
