awwdabaaby
Newbie
Message 1 of 5
Home hub 5 keeps loosing connection
I have the home hub 5 and was having connection issues so was sent a new one but it seems this new one drops connection more often, I have changed the settings in the admin as advised by BT but still problem is there. Anyone else having this problem or suggest anything?
4 REPLIES 4
Message 2 of 5
Re: Home hub 5 keeps loosing connection
if using hh5 then post stats - troubleshooting then helpdesk
try quiet line test  dial 17070 option 2 should be quiet and best with corded phone
have you tried connecting to test socket with a new filter - even if you have a filtered master socket
awwdabaaby
Newbie
Message 3 of 5
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34212690
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 11/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 02:38:18
6. Data rate:20000 / 79903
7. Maximum data rate:26998 / 85767
8. Noise margin:9.7 / 7.3
9. Line attenuation:8.1 / 9.5
10. Signal attenuation:8.0 / 9.5
11. Data sent/received:2.5 GB / 5.8 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-8GMP
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-8GMP
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:62:2c:2e:c6:8a
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Message 4 of 5
apart from short connection time stats look good with max 80/20mb for infinity 2  disconnection do not as yet appear to be affecting your connection speed
awwdabaaby
Newbie
Message 5 of 5
Any ideas on how to resolve this as I'm still having connection issues
