Mckitter
Newbie
Message 1 of 7
Home hub keeps going orange, event log included
Hi, can anyone tell me why thus keeps happening? It is continually going orange, especially at night.
Device Connected: 192.168.1.151, e8:61:7e:43:8c:1d, unknown
17:45:18, 28 Nov. 2.4G Client associate from e8:61:7e:43:8c:1d (IP=192.168.1.151) RSSI=-63, Rate=6Mbps, host
17:45:16, 28 Nov. Receive a DHCP request
17:44:51, 28 Nov. DSL Link Up: Down Rate=32602Kbps, Up Rate=8188Kbps; SNR Margin Down=5.3dB, Up=6.0dB
17:44:36, 28 Nov. WAN connection PTM disconnected
17:44:27, 28 Nov. PPP LCP Send Termination Request (User request)
17:44:24, 28 Nov. PPP LCP Send Termination Request (User request)
17:44:23, 28 Nov. DSL Link Down: duration was 125 seconds
17:44:06, 28 Nov. Device Connected: 192.168.1.221, 4c:4e:03:95:13:67, android-5b04b3fae331f207
17:44:05, 28 Nov. 5G Client associate from 4c:4e:03:95:13:67 (IP=192.168.1.221) RSSI=-76, Rate=12Mbps, host android-5b04b3fae331f207
17:44:04, 28 Nov. Receive a DHCP request
17:43:08, 28 Nov. NTP synchronization success
17:43:01, 28 Nov. Device Disconnected: 192.168.1.221, 4c:4e:03:95:13:67, android-5b04b3fae331f207
17:42:55, 28 Nov. NTP synchronization start
17:42:54, 28 Nov. 5G Client diassociate from 4c:4e:03:95:13:67 (IP=192.168.1.221) RSSI=-70 , Rate=234 Mbps
17:42:53, 28 Nov. WAN connection PTM connected
17:42:52, 28 Nov. PPP IPCP Receive Configuration ACK
17:42:52, 28 Nov. PPP IPCP Send Configuration Request
17:42:52, 28 Nov. PPP IPCP Receive Configuration NAK
17:42:52, 28 Nov. PPP IPCP Send Configuration ACK
17:42:52, 28 Nov. PPP IPCP Receive Configuration Request
17:42:52, 28 Nov. PPP CHAP Receive success : authentication successful
17:42:51, 28 Nov. PPP CHAP Receive Challenge
17:42:51, 28 Nov. PPP LCP Receive Configuration ACK
17:42:51, 28 Nov. PPP LCP Send Configuration ACK
17:42:51, 28 Nov. PPP LCP Receive Configuration Request
17:42:51, 28 Nov. PPP LCP Send Configuration Request
17:42:20, 28 Nov. DSL Link Up: Down Rate=32667Kbps, Up Rate=8271Kbps; SNR Margin Down=5.3dB, Up=6.0dB
17:42:11, 28 Nov. Device Disconnected: 192.168.1.90, 70:ec:e4:27:b1:38, iPhone
17:42:09, 28 Nov. Device Connected: 192.168.1.90, 70:ec:e4:27:b1:38, iPhone
17:42:06, 28 Nov. WAN connection PTM disconnected
17:42:02, 28 Nov. 2.4G Client diassociate from 70:ec:e4:27:b1:38 (IP=192.168.1.90) RSSI=-61 , Rate=39 Mbps
17:41:57, 28 Nov. PPP LCP Send Termination Request (User request)
17:41:54, 28 Nov. PPP LCP Send Termination Request (User request)
17:41:53, 28 Nov. DSL Link Down: duration was 453 seconds
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Home hub keeps going orange, event log included
Hi @Mckitter and welcome.
I'm sorry you're having problems with the connection dropping. Can you check the line for noise by connecting a phone to the test socket and dialling 17070 option 2?
Cheers
David
Mckitter
Newbie
Message 3 of 7
There is a low hum
Sage
Sage
Message 4 of 7
If that is with a corded phone report a line fault on 151. Don't mention broadband.
Moderator
Moderator
Message 5 of 7
Thanks for checking that @Mckitter.
Was that on a cordless or corded handset?
***Edit*** you beat me tp it @pippincp Smiley Happy
Cheers
David
Mckitter
Newbie
Message 6 of 7
Corded phone. I have raised the fault online already, it says problem on the line. I was just double checking for opinions on the event log, I have been reading some horror stories about engineer call out charges and trying to eliminate this being a fault of my own.
Mckitter
Newbie
Message 7 of 7
By the way, thanks for help guys!
