Starburst
Message 1 of 11
HomeHub 5 Stats
I have an ongoing issue with very low afternoon and evening download speeds and await an answer to my letter to BT.
In the meantime could someone please say if there is anything in my HH5 stats that gives cause for concern:-
1.     Product Name:     HomeHub5
2.     Serial number:     +076286+1505002437
3.     Firmware version:     v0.07.03.0814-BT (Type B) Last updated [Unknown]
4.     Board version:     01
5.    VDSL uptime:    6 days, 09:45:55
6.    Data Rate:    9999 / 40000
7.    Maximum Data Rate:    30216 / 89744
8.    Noise Margin:    21.7 / 20.3
9.    Line Attenuation:    0.0 / 9.7
10.    Signal Attenuation:    0.0 / 0.0
11.    Data sent/received:    702.7 MB / 6.6 GB
12.    Broadband username:    bthomehub@btbroadband.com
13.    BT Wi-fi:    Yes
14.    2.4GHz wireless network/SSID:    BTHub5-J8HM
15.    2.4GHz wireless connections:    Enabled (802.11 b/g/n (up to 144 Mb/s))
16.    2.4GHz wireless security:    WPA2 Only (Recommended)
17.    2.4GHz wireless channel:    Automatic (Smart Wireless)
18.    5GHz wireless network/SSID:    BTHub5-J8HM
19.    5GHz wireless connections:    Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20.    5GHz wireless security:    WPA2 Only (Recommended)
21.    5GHz wireless channel:    Automatic (Smart Wireless)
22.    Firewall:    Default
23.    MAC Address:    4c:09:d4:b3:6f:55
24.    Software variant:    -
25.    Boot loader:    0.5.0-BT (Tue Jun 17 18:52:56 2014)
BT Home Hub 5 (Type B) | Software version v0.07.03.0814-BT  | Last updated [Unknown]
10 REPLIES 10
Message 2 of 11
Re: HomeHub 5 Stats
Stats look ok with stable 6 days connection time and speed max 40/10 for infinity 1
Message 3 of 11
Re: HomeHub 5 Stats
Your hubstats are fine you are connecting at the maximum connection speed for infinity 1
are you using a wired connection when doing the speedtest
Starburst
Message 4 of 11
Re: HomeHub 5 Stats
Yes, using an ethernet connection, John. Thanks for that.
My post was related to previous posts about very slow Infinity speeds in the late afternoon and early evening and another about line noise that I could hear with a quiet line test last Sunday.
An engineer called today and made checks in my house, the exchange and nearby cabinets. No problem found. He re-made connections in the cabinets as a precaution.
It was yourself, I recall, that mentioned the slow Infinity problem I described sounds like congestion. I asked the engineer if there is a congestion problem and he confirmed there is. He said it is with the "backhaul" (think you mentioned that, too).
He reckons that something will get done about increasing the capacity - eventually.
The more folk that buy Infinity and get a problem the more will be the complaints. Hopefully that will trigger improvements.
Message 5 of 11
Re: HomeHub 5 Stats
correct all that can be done is wait I am afraid
Moderator
Moderator
Message 6 of 11
Moved:
Re: HomeHub 5 Stats
Starburst
Message 7 of 11
Re: HomeHub 5 Stats
john46 wrote:-
"Re: HomeHub 5 Stats
correct all that can be done is wait I am afraid"
13 days ago I put a written complaint to BT about my low Infinity speeds. A BT engineer from Leicester phoned a short while ago in response to my letter. He knew about the Openreach engineer's visit this morning. He said that he does not think the problem is congestion causing my low speeds.
He has arranged for a broadband engineer to call on Wednesday (afternoon visit when the download speeds are dropping). I'll post the result of that visit. It may be of interest to someone.
I am glad that an interest is being taken in the problem.
Message 8 of 11
Re: HomeHub 5 Stats
Can you run btspeedtester diagnostic test and post results to show if download low
Starburst
Message 9 of 11
Re: HomeHub 5 Stats
 5. VDSL uptime: 0 days, 10:55:31
7. Maximum Data Rate: 30853 / 92239
8. Noise Margin: 22.5 / 20.6
11. Data sent/received: 111.7 MB / 800.4 MB
13. BT Wi-fi: Yes
Speed  Down  3.79   Up 8.61
Hope that is what you need.
Do not want to go password changing for testing .
Message 10 of 11
Re: HomeHub 5 Stats
I was just trying to see if download speed still terrible hens asking for btspeedtester diagnostic test.
btspeedtester
