Distinguished Guru
Message 1 of 11
Homehub 5 (Type A)
I had a Homehub 5 (Type A) turn in my letterbox yesterday, unannounced.
Soooo, I connected it up yesterday evening and it instantly synced up at 75/19.5 happy days.
However, I've just checked and the connection rebooted (CWMP) a couple of hours ago.
Now it's
Line state:Connected
Connection time:0 days, 01:57:48
Downstream:63.25 Mbps
Upstream:19.53 Mbps
What's going on? 😞
If not, I'll try again 🙂
Tags (1)
10 REPLIES 10
Message 2 of 11
Re: Homehub 5 (Type A)
noise margin about normal or scope for improvement?
Distinguished Guru
Message 3 of 11
It's currently at 6.5 so that's where my speed has gone.
Message 4 of 11
it looks like the small amount above normal can have a significant effect on your speed unlike adsl which 6.5db would be classified normal
Distinguished Guru
Message 5 of 11
Yeah. I'm just bemused why CWMP decided to change some options and do a reboot.
Distinguished Guru
Message 6 of 11
Another day another reboot
Connection time:0 days, 10:19:23
Downstream:63.31 Mbps
Upstream:19.53 Mbps
5. VDSL uptime:0 days, 10:18:45
6. Data rate:19999 / 64829
7. Maximum data rate:27428 / 77857
8. Noise margin:7.5 / 6.5
What is CWMP playing at?
lisa107b
Message 7 of 11
Hrm, that looks like my figures from yesterday, in fact very similar:
5. VDSL uptime:0 days, 01:08:07
6. Data rate:20000 / 66606
7. Maximum data rate:22997 / 76998
8. Noise margin:7.5 / 6.7
9. Line attenuation:0.0 / 16.4
....Are they up to something?
Had some nasty problems this morning too, now I have a 6.0 / 6.5 noise margin and a sync speed of 56Mbps
Distinguished Guru
Message 8 of 11
Well, only they know what they're doing and so far, they ain't saying nothing 😉
Distinguished Guru
Message 9 of 11
Well it's broken through the 1 day uptime limit. I wonder if I'll ever see full speed again? 😞
5. VDSL uptime:1 days, 07:51:05
6. Data rate:19999 / 64975
7. Maximum data rate:27571 / 77571
8. Noise margin:7.9 / 6.5
Distinguished Expert
Message 10 of 11
Your noise margin figures seem to fluctuate as much as mine.
However, there's still only 3 resets of connection in what is now 6 days. There was one reboot on day 2, which resulted in a defined date of software version install.
Similar reduction in down speed, but the upload speed is improving slowly - now at around 16.5, from 12 at the start.
I can imagine that a small change in noise margin (dB) will produce a larger change on download speed than ADSL2.
