Moderator
Moderator
Message 31 of 46
Re: Horrible ping spikes and packet loss
Hi @Taker44,
I've made some changes to your broadband service directly with our supplier. It's due to complete on Tuesday. Part of my  order is for a super stable service. I want to see if this will help you before we look into sending out any engineer. I can check in with you on Wednesday to see if you've noticed any improvement. Would this suit you ok? If my changes don't have the desired effect I can place an order to change you back to the current service within a couple of days.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Taker44
Message 32 of 46
Hi Daniel
Would there be any billing/costs for this change for me? I just don't want to be hit with any additional charges on my next bill/s or internet package contact renewals without knowing.
Moderator
Moderator
Message 33 of 46
Hi @Taker44,
There will be zero additional charges for the changes that I am making for you. It won't affect your contract either. I won't make any changes that will affect the cost or contract length without discussing and agreeing beforehand Smiley Happy
DanielS
Kudos”Kudos”
Taker44
Message 34 of 46
Okay, Daniel. I will wait and see if I get any improvements on Wednesday. Thanks.
JonathanAnsell
Message 35 of 46
@DanielS What other types of service are there? I’m guessing there’s super stable and a standard one at the very least but is there a speed one?
If there is, is it requestable?
Sage
Sage
Message 36 of 46
The speed one would make ping worse, definately not for you or your issue.
Moderator
Moderator
Message 37 of 46
Hi @JonathanAnsell,
Besides from the standard option there are two other stability options that we can choose. They are stable and super stable.
DanielS
Kudos”Kudos”
JonathanAnsell
Message 38 of 46
Thanks for clarifying @DanielS
Would it be fair to assume everyone is on a standard profile unless they have BT TV or like the thread starter it has been requested to be changed?
akjmoran
Message 39 of 46
Hi Taker44,
If you don’t mind please could you let me know how this goes? I am having the same issues as you with ping spikes and if this request for a stable line over speed works then maybe it is something I should look to get. Thank you in advance
Taker44
Message 40 of 46
Success! I am reporting back that there is a complete day and night difference with shadow. I tried this afternoon and it is working so much better now. Absolutely zero packet loss. Before packet loss was constant. The ping spikes are also tiny now, just a few ms here and there which doesn't affect the experience. Before I was spiking every few seconds going all the way up to 200ms at times. It was unworkable before but now it's great! I will make a new thread if I get issues again but I think this super stable change seems to have done the trick. Thank you everyone for your help and advice.
