Message 11 of 31
Re: How can I tell if I have been switched from ADSL to Infinity One
with up profile of 0.83mb then adsl2+ not fibre
Message 12 of 31
Yep something has gone wrong with the order. As the order is now closed I think you'll need to raise it as a fault. Engineer visit is required.
bl00tered
Message 13 of 31
Onto BT just now. They are saying it is probably and IP Profile mismatch
Message 14 of 31
@imjolly wrote:
if you have a hh5 then troubleshooting then helpdesk and then what does it say a no 24 modulation
did you check what was shown?  possibly 992.5?
Message 15 of 31
It's not an IP profile mismatch. You're not on FTTC.
Message 16 of 31
If it is a Hub 5b Modulation is not shown
Distinguished Guru
Message 17 of 31
The HH5 stats are available from  bthomehub.home  > Troubleshooting > Helpdesk.
It think it's like this?
The HH5A shows DSL on line 5 and the modulation type on line 24.
The HH5B shows ADSL or VDSL on line 5, but doesn't show the modulation type.
Moderator
Moderator
Message 18 of 31
@bl00tered how did you get on with the helpdesk earlier?
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
bl00tered
Message 19 of 31
Hi, Apologies for the late response.
This from the helpdesk
1.     Product Name:     HomeHub5
2.     Serial number:     +076286+1545006309
3.     Firmware version:     v0.07.05.0A13-BT (Type B) Last updated 19/2/2016
4.     Board version:     01
5.    ADSL uptime:    0 days, 13:33:24
6.    Bandwidth:    1143 / 12539
7.    Data sent/received:    314.1 MB / 4.8 GB
8.    Broadband username:    bthomehub@btbroadband.com
9.    BT Wi-fi:    No
10.    2.4GHz wireless network/SSID:    BTHub5-JKXX
11.    2.4GHz wireless connections:    Enabled (802.11 b/g/n (up to 144 Mb/s))
12.    2.4GHz wireless security:    WPA2 Only (Recommended)
13.    2.4GHz wireless channel:    Automatic (Smart Wireless)
14.    5GHz wireless network/SSID:    BTHub5-JKXX
15.    5GHz wireless connections:    Enabled (802.11 a/n/ac (up to 1300 Mb/s))
16.    5GHz wireless security:    WPA2 Only (Recommended)
17.    5GHz wireless channel:    Automatic (Smart Wireless)
18.    Firewall:    Default
19.    MAC Address:    a8:d3:f7:4f:2a:c3
20.    VPI/VCI:    0/38
21.    Modulation:    G.992.5(ADSL2+)
22.    Latency type:    Fast
23.    Software variant:    -
24.    Boot loader:    0.5.1-BT (Wed Nov 12 11:52:05 2014)
BT Home Hub 5 (Type B) | Software version v0.07.05.0A13-BT  | Last updated 19/2/2016
bl00tered
Message 20 of 31
