Apreest
Message 1 of 4
How do I connect Ethernet cable to tv box
I have moved into a new build home, The modem is in the garage which is attached to the house. So I’ve plug the WAN cable from the modem to router but as it’s in the garage I can’t conncet it to my bt tv box any ideas?
3 REPLIES 3
Devon_Dave
Distinguished Guru
Message 2 of 4
Re: How do I connect Ethernet cable to tv box
Best solution would be using power line adaptors.
One of the adaptors would plug into an electric socket adjacent to the modem/router. You plug an Ethernet cable from the adapter into the router.
The other adapter plugs into an electric socket adjacent to your tv box. Once again connect an Ethernet cable from the adapter into the tv box.
The powerlines use the electrical cable in your house to transfer the signal from the router to the tv box.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
licquorice
Message 3 of 4
2 choices.
Run an Ethernet cable or use powerline adaptors such as these https://www.shop.bt.com/products/bt-broadband-extender-600-kit-084284-BVFL.html
Keith_Beddoe
Message 4 of 4
Use the BT Mini Connectors.
http://bt.custhelp.com/app/answers/detail/a_id/57213/~/bt-mini-connectors-for-bt-tv
They are available at a discounted cost of £20 at the time of ordering, or if you are an existing BT YouView customer.
You have to do it via the the online TV orders chat team
This post by a moderator explains it.
https://community.bt.com/t5/YouView-from-BT/How-to-connect-YouView-Box-when-hub-in-another-room/m-p/...
