thempstead
Message 1 of 9
How do you get BT to actually sort out a problem?
Have had Infinity 2 for many years and it has run stablely at ~68Mbps down ~12Mbps up all that time.
Over the last 3-4 days I have been having issues though
1. When talking to people on my landline I hear static when they talk but they hear me fine with no issues.
2. My broadband speed seems to have dropped to ~34Mbps down ~0.4Mbps up
Trying to raise a ticket the auto line test comes back ok (despite 1) and for 2 they just talk about changing wifi channels on a home hub (when I have already stated that I am connected over wired rather than wifi).
8 REPLIES 8
gg30340
Message 2 of 9
Re: How do you get BT to actually sort out a problem?
If you have noise on your phone you need to report a phone fault not a broadband fault. Once the phone fault is fixed your broadband will improve.
thempstead
Message 3 of 9
Issue with that is that the automatic line test comes back with no fault found ...
Keith_Beddoe
Message 4 of 9
The line test cannot detect that type of fault unless there is an actual battery or earth fault on the line.
imjolly
Message 5 of 9
have you checked that the noise still exists if you try the test socket with a filter?  if the problem causing the static phone interference is due to an internal problem then you will probably be charged £85 for engineer callout.  so test first before phoning 151 and reporting phone fault
pippincp
Sage
Message 6 of 9
Just  in case you don't know. 17070 option2 for the quiet line test.
thempstead
Message 7 of 9
Ok, ... I still get noise if I'm using the test socket and I can hear noise on the line if I do that quiet line test.
Looking at the openreach modem some of the reported stats are a bit odd ...
Downstream shows an a rate which seems normal with a SNR of 20 and a line attenuation of 12.4
Upstream looks bad with an attainable rate of <1MB, a SNR of 0 (zero) and a line attenuation of 10.5
The upstream is also showing vast numbers of HEC errors (as in a ten-digit numbers worth).
Note that the cable to the modem is hard wired into the master socket and was installed by BT when I originally got Infinity in this property
thempstead
Message 8 of 9
ok, according to Google the gui stats are probably wrong ...
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 985 Kbps, Downstream rate = 67188 Kbps
Bearer: 0, Upstream rate = 953 Kbps, Downstream rate = 63025 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 4.8 8.6
Attn(dB): 20.0 0.0
Pwr(dBm): 12.4 10.5
So whys the upstream rate gone through the floor ...?
licquorice
Message 9 of 9
Just report the noisy line fault and get it fixed.
