Jleyland1239
Message 1 of 2
How long at 'Activate stage' usually?
Hello, after being in the connect stage for a few months today we are now in the Activate stage on the Openreach site, anyone with previous experience who are now connected if you could say roughly how long the process took it would be much appreciated, for reference my postcode is WA95UF, thanks.
1 REPLY 1
Sage
Sage
Message 2 of 2
Re: How long at 'Activate stage' usually?
How long's a piece of string? Unfortunately there is no set or average time. Any stage of the process can be hit with delays such as blocked ducts etc.
All you can do is check HERE regularly.
