maffie587
Message 1 of 9
How long is too long?
I reported slow speeds to BT back on the 2nd May.  We went through the speed tests and all the other checks and they agreed there was a problem.  A report has been filed, and I can see it when I log in.  However, the picture of the BT buildings hasn't changed and the slow speed is still there
Should BT be taking over 4 weeks, and not showing any movement on my file
Fault number
VOL012-xxxx
Date reported
2 May 2016
Current status
In-Progress
Product affected
Broadband fault
Telephone number
017xxxxx
Many Thanks
Matt
8 REPLIES 8
Message 2 of 9
Re: How long is too long?
it depends on what the fault is and how long it takes Openreach to resolve
Is anything showing here for your exchange http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Message 3 of 9
as your internet is still wiorking if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
are you using the test socket with a new filter
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
maffie587
Message 4 of 9
 Thanks for replying so quickly.  Only just got home from holiday, so I'm a bit slow in replying.  Here are the results as requested
Matt
1. Product name:
BT Home Hub
2. Serial number:+068543+NQ60212575
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 15/04/16
4. Board version:BT Hub 5A
5. DSL uptime:10 days, 18:25:07
6. Data rate:312 / 39993
7. Maximum data rate:320 / 52790
8. Noise margin:6.2 / 10.6
9. Line attenuation:2.5 / 20.1
10. Signal attenuation:2.4 / 18.6
11. Data sent/received:888.9 MB / 22.8 GB
12. Broadband username:bthomehub@btbroadband.com
Download 12.13
Upload 0.25
Ping 43
Exchange WEST MALLING is served by Cabinet 20
VDSL Range A (Clean)53.54013.58.8--Available----
VDSL Range B (Impacted)4022.410.65.1--Available----
WBC ADSL 2+Up to 7--6 to 8Available----
WBC ADSL 2+ Annex MUp to 7Up to 16 to 8Available----
ADSL MaxUp to 4.5--3 to 7.5Available----
WBC Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Message 5 of 9
Was the speedtest done with a wired or wireless connection?
gt94sss2
Message 6 of 9
To me it like either a line fault or your Home Hub is faulty - just look at the upload speed and the attenuation it is reporting.
if you haven't, I would try leaving the home hub disconnected overnight when no one is using it and seeing if lines 6/7/9 improve when you reconnect it. Ideally try a new filter as well if you have one.
if that doesn't help you may want to borrow a home hub from a friend to see if the line results are similar - otherwise I think you need an engineer
maffie587
Message 7 of 9
Thanks for the answers everyone.  The test was wired.  I'll leave the hub off overnight and re-do the tests again.  The filter was a new one that came with the hub.
Thanks again
Matt
maffie587
Message 8 of 9
1. Product name:BT Home Hub
5. DSL uptime:0 days, 00:13:10
6. Data rate:292 / 50766
7. Maximum data rate:297 / 51002
8. Noise margin:6.0 / 6.1
9. Line attenuation:2.8 / 20.4
10. Signal attenuation:2.8 / 18.9
11. Data sent/received:380.5 MB / 6.8 GB
Turned everything off overnight.  Retested and 6/7/9 don't seem to have improved.  I've got a direct feed into the test socket and the speeds from BT Wholesale site are 11.29 down/0.26 up/54.63 ping.
Think I might need to upgrade to an engineer
Paste from BT Performace page after changing domain name for my records to BT
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 12.08 Mbps
0 Mbps49.14 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 12.08 Mbps
 For your connection, the acceptable range of speedsis 34.4 Mbps-49.14 Mbps .
 Additional Information:
 IP Profile for your line is - 49.14 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.21 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.21Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Please visit the FAQ if you are unable to understand the test results.
Distinguished Guru
Message 9 of 9
Hi. Can I suggest you don't keep switching the hub on and off. This will not help you achieving the maximum speed your line will support.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
