MATTHEWATLANT0S
Message 1 of 3
How to check firmware version on BT Home Hub 6.
Hello,
I have a BT home hub 6 router, and I trying to find the version of firmware installed on the router can not find the firmware version on the main page of the router, also has the following problems with the router have reset the router and BT checked the phone line and tell me no problems found. the problems I am facing are that sometimes the internet is very fast or times the internet is very slow on some of the internet channels the picture sometimes goes like coloured water and on BT sport channels the picture is brilliant.
Any help would be great.
Matthew
2 REPLIES 2
Message 2 of 3
Re: How to check firmware version on BT Home Hub 6.
Advanced settings > Technical log > information
You can't do anything about the firmware version, it is not user updateable.
Message 3 of 3
Or I assume you can just press the Status button?
