Message 21 of 31
Re: How to get FTTP - strange issue with our property specifically
It will be on the pole that serves the properties.
Message 22 of 31
I do not see this green box, only the poles with two cables running. One is thicker. Is the box supposed to be there, what is it?
The cables split at a pole about 10 m from the house they go one direction to us (no FTTP available) and the other to our rental cottages, all three of whom can get FTTP according to the OpenReach website.
Message 23 of 31
Its a fibre splitter that distributes the individual fibres to the properties. Did you speak to the FTTP team on the number I posted?
Message 24 of 31
Not not yet, I have been out taking photos of the pole. This is what is attached (the yellow sticker says caution fibre ahead):
Message 25 of 31
That number takes me to an automated line and I cannot get access to a specific FTTP team, first I was asked if I wanted BT infinity then BT TV.....it wasn't very helpful.
Message 26 of 31
Yep, FTTP
Message 27 of 31
Hi licquorice
Thanks for that number, it helped a lot. We now have the options for the installation.
We also have a business line and I need to call a different number to see if this is a connection option but it may not be.
Sage
Message 28 of 31
If you can get residential FTTP then you can get business FTTP (that is a fibre splitter on the pole).
However for business you'll get help and advice from here.
https://business.forums.bt.com/t5/Broadband-and-internet/bd-p/Broadband
Message 29 of 31
They’re not Splitters. They’re Pole Mounted FTTP DP’s for Legacy (Blown Fibre).
Message 30 of 31
The 'thing' in the top picture was installed on our pole in January and the engineers called it a splitter - has ports for connectorised fibre.
