Taf
Newbie
Message 1 of 17
How to increase upload speed on BT Hub 6
Hi there
I have had the BT hub 6 for the last 2 months and in the last 2 weeks my upload speed has dropped to under 1mbps
I had an bt engineer visit and he said I had fibre to the wall socket. Tested directly from the socket and advised he got 13 mbps upload. He checked two different cables to the hub and both were below 1 mbps
He advised to get an new hub which I received today however I am having the same issue.
My download speed is fine.
Does anyone know what the issue is please?
16 REPLIES 16
Message 2 of 17
Re: How to increase upload speed on BT Hub 6
@Taf
Welcome to this user forum.
Are you sure you are not confusing Megabytes with Megabits. 13 Megabits = 1.625 Megabytes
As you have FTTP (Fibre to the Premises), there should be no external factors.
Please can you please provide http://speedtest.btwholesale.com/  results, including the further diagnostics page?
These must be done using a computer connected to the home hub, using an Ethernet cable.
Sage
Sage
Message 3 of 17
@Keith_Beddoe  He can't have FTTP as it's not supplied to a wall socket.
Message 4 of 17
I did wonder, but it could have been extended to an wall mounted Erhernet socket, with the ONT in a cupboard.
Sage
Sage
Message 5 of 17
Possible but highly unlikely Keith, it would be the first I've heard of.
Taf
Newbie
Message 6 of 17
Thanks Keith and Pippinpc
I have run the test and the results are below
Best Effort Test: -provides background information.
 Download speedachieved during the test was - 51.54 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-53.23 Mbps .
 Additional Information:
 IP Profile for your line is - 53.23 Mbps
2. Upstream Test: -provides background information.
Upload speed achieved during the test was - 0.88Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
Message 7 of 17
Perhaps its your computer limiting the upload speed, or it running a task which is uploading in the background. This can happen with Windows 10, if your Windows update settings are allowing you to share your upload bandwidth with other users. This is the default setting, so have you disabled it?
Message 8 of 17
Some hub stats would be nice...if it's not FTTP.
Taf
Newbie
Message 9 of 17
I have tried two computers and I do think there maybe some programs running in the background but I have also tried two mobile phones and stood next to the hub and done an speed test via wifi.
And the results are the same
Thing is it was working fine from January until the last two weeks
Are the these the hub stats you were asking about
Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4:
BT Infinity
Firmware version:
SG4B10002244
Firmware updated:
21-Mar-2017
Serial number:
+084316+NQ63197875
Downstream sync speed:
55.00 Mbps
Upstream sync speed:
9.99 Mbps
Network uptime:
0 Days, 1 Hours 12 Minutes
System uptime:
0 Days, 1 Hours 14 Minutes
BT Wi-fi status:
Not active
Message 10 of 17
This link provides more info
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Did you do the mobile  phone test, with no other computers turned on?
