Ralphy22
Message 1 of 4
How to limit upload speed?
How do I limit my upload speed to stop it maxing out and effecting my download speeds which are dropping really low when i upload a video
3 REPLIES 3
Message 2 of 4
Re: How to limit upload speed?
if you are using a hub then you can't change upload speed
Ralphy22
Message 3 of 4
What can you do
Message 4 of 4
Its possible to limit download speed using QoS on third party routers but I don't know if it is possible to limit upload.
Edit.  Should have checked first, yes it is certainly possible on my TP-Link TD-W9980 so expect it will be possible on other routers.
