Message 1 of 4
How to make by install fibre to this address
Hi all, in Croydon right next to Reedham train station. It’s literally outside my front door, and been told fibre is at this station and all around this address, but bt and every internet company only over a speed guarantee of 3mb which is quite frankly shocking in 2022. I seriously can’t believe how bad the internet is just on this row of houses, how do I go about getting this resolved? Does anyone have any tips? I cannot get by on this speed.
3 REPLIES 3
Message 2 of 4
Re: How to make bt install fibre to this address
@stewarthastings
This would have nothing to do with BT Retail, you would have to ask Openreach.
Try https://www.openreach.com/broadband-network/fibre-availability
Message 3 of 4
ok thanks for info. So 3mb until before December 2026, great infrastructure we have here, wtf
Message 4 of 4
Have you taken this up with other Fibre provider's, it's not only Openreach that install Fibre.
EDIT: I see you have posted on The Virgin Forum with the same question.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
