boe323
Message 1 of 3
Hows this possible ?
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 49.33 Mbps
0 Mbps48.07 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 49.33 Mbps
 For your connection, the acceptable range of speedsis 33.65 Mbps-48.07 Mbps .
 Additional Information:
 IP Profile for your line is - 48.07 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 7.59 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 7.59Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Hows this possible ?
Which modem and router are you using?
If not, I'll try again 🙂
boe323
Message 3 of 3
Its the hg612 modem and have hhb5typeb attached to it.
