markeagles4
Message 1 of 13
Hub 6 Broken Down
Seems its finaly given up wont even turn on now , not sure what i put up with it for this long (prob because not everyone can afford a fancy 3rd party) what happens now ? have i got to pay for a new one 😞 whats the warranty on these.
Could a mod have aloom into this as im having to use an old hub5 (whitch the wifi dont work) 😞
MArk
12 REPLIES 12
Message 2 of 13
Re: Hub 6 Broken Down
Are you still in a fixed term contract with BT not a rolling monthly contract? If so BT will replace the faulty router for free just phone customer services. However if you are not in a fixed term contract then hh6 belongs to you and up to you to fix or replace
Message 3 of 13
You do not need a "fancy" third party router. A perfectly good VDSL Modem/router starts in price at £30.
However if as has been pointed out you are still in contract the BT hub will be replaced free of charge if it is faulty and it does not take a moderator to arrange this. You need to phone BT and report the fault.
markeagles4
Message 4 of 13
Fixed term untill next march I think. Thanks I'll call them up
Moderator
Moderator
Message 5 of 13
Hi @markeagles4,
Did you get everything sorted when you called up?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
markeagles4
Message 6 of 13
Hi,
Yes I did thank you new one on its way hopefully tomorrow morning.
Moderator
Moderator
Message 7 of 13
Perfect @markeagles4.
Let us know if everything's working for you ok tomorrow Smiley Very Happy
DanielS
Kudos”Kudos”
markeagles4
Message 8 of 13
Recoived yesterday , Hub is on really old firmware, WPS is broken just flashes red when pressed , factory reset the unit unable to connect to wifi says my password is wrong (using stock pass etc) changed password and then rest back to original it worked for a while now all my devices constantly disconnect / reconnect grrrrrrr , so reset device again says password is wrong again , theis was a recon unit , box was all bashed up on the underneath .
Mod please recify this , my other hub was solid even with all the horror stories i was blessed with a perfect unit now im just sad .
Message 9 of 13
If you need something to get you connected right away, then do as @gg30340 suggested, even if you keep it as a spare after you get a working home hub 6.
You should be able to get one locally. Please ask if you need specific details.
Moderator
Moderator
Message 10 of 13
@markeagles4 Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Kudos”Kudos”
