Message 1 of 4
Hub connection
I had a hub 3 connected to an Openreach box.
I now have a smart hub 2 plugged into the main socket (as per instructions) and all works ok.
Can I dispose of the Openreach box?
3 REPLIES 3
Message 2 of 4
Re: Hub connection
Yes, you can take it to your local re-cycling centre.
Message 3 of 4
Re: Hub connection
Or sell it on Ebay, there is still a healthy market for Openreach modems.
Message 4 of 4
Re: Hub connection
