TomV87
Message 11 of 13
Re: Hub flashing purple
Due to the location of plug sockets and where the TV it will be into the extension
i have the microfilter plugged in then the phone and broadband.
The main socket is right by my front door so impractical
TomV87
Message 12 of 13
Just a quick update,
On my lunch break i tried it at the main socket and found the same problem.
Is there anything else I should try before contacting BT
TomV87
Message 13 of 13
All sorted, hub was faulty.
Thanks all
