Indiejones80
Message 1 of 41
Hub going from Blue to orange - Engineer been out
My dads smart-hub 6 on BT Infinity started to go from blue to orange with no real pattern the hub has been fine for a year and it’s only in December this started.
After reporting they did line tests and said that there was a network fault which indicated in the house. Before we got an engineer we decided to:
Swap out the filters to new, replace the cable from the master socket (Open-reach NTE5) we even decided to buy a new replacement hub from ebay. We disconnected the phone in case that was causing the issue.
Open reach silent call test comes back fine and clear.
Still was going to orange randomly.
We had an engineer out yesterday, he checked everything and he thought that there could be interference from a secondary socket. He changed the master socket (still a NTE5) but now it doesn’t need a filter the cable to router now comes out the side. The phone that was on the secondary is now connected to the hub.
Still is going orange.
Rang again today and I was told we need to wait 5 days for the new socket to settle?!? Sounds like a fob off.
We have tried 3 smart hub 6’s (I brought my one round to his) swapped everything out, new master installed. BT still don’t think the error is on there side?!
BT said they can see the constant drop off from the router and only once on the phone line.
Sorry I don’t have a log I can copy, as I’m away from the hub.. When i looked on the WAN log it was dropping connection and reconnecting after a few seconds.
any advice?
40 REPLIES 40
DavidM
Moderator
Moderator
Message 2 of 41
Re: Hub going from Blue to orange - Engineer been out
Hi @Indiejones80 and welcome.
You've mentioned a secondary socket. Is that an extension? Is it connected?
Cheers
David
Indiejones80
Message 3 of 41
I will have to check, there is nothing on that secondary line anymore I don’t know if the engineer disconnected it though
FocusTech
Message 4 of 41
Ok i have seen this before on several occasions...
Cheap nasty Christmas Tree lights or other lit decorations.
Baby monitors.
A faulty cordless phone base.
Anything added to the property at the point it started happening that is electrical?
I have even had microwaves killing wifi connections!
Also, unplug everything bar the router in the master socket and see what happens.
Also replace microfilters.
Indiejones80
Message 5 of 41
Also yes it was an extension spurred off the master
Indiejones80
Message 6 of 41
We did think it could be the Xmas lights they are gone now though and it’s still happening.. we had two filters both replaced but now we dont have any the cordless phone base got plugged into the hub yesterday and like I said in my original post the master socket the hub is directly wired in now with no need for a filter by the engineer
Indiejones80
Message 7 of 41
So slight update the box is going from blue to orange far more now. Also my dad called to say that he had checked the secondary socket and the engineer disconnected it from the master
FocusTech
Message 8 of 41
If you have a phone handy is the line noisy and crackly when you make a call?
Indiejones80
Message 9 of 41
No there is no noise it’s very clear, plus the quiet test was fine
Indiejones80
Message 10 of 41
Here is a copy of a section of the log:
10:19:37, 06 Jan.
:WAN: SENSING AUTO VDSL
10:19:06, 06 Jan.
ptm0.101:VLAN VLAN_DATA connected
10:19:06, 06 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
10:19:06, 06 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
10:19:06, 06 Jan.
dsl:VDSL link Up: Down Rate=75257Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
10:18:48, 06 Jan.
:VLAN VLAN_DATA disconnected
10:18:43, 06 Jan.
dsl:VDSL Link Down: duration was 572 seconds
10:09:44, 06 Jan.
10:09:12, 06 Jan.
10:09:11, 06 Jan.
10:09:11, 06 Jan.
10:09:11, 06 Jan.
dsl:VDSL link Up: Down Rate=75103Kbps, Up Rate=26944Kbps, SNR Margin Down=15.30dB, SNR Margin Up=6.00dB
10:08:54, 06 Jan.
10:08:50, 06 Jan.
dsl:VDSL Link Down: duration was 36 seconds
10:08:14, 06 Jan.
10:08:14, 06 Jan.
10:08:14, 06 Jan.
10:08:14, 06 Jan.
dsl:VDSL link Up: Down Rate=75535Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
10:08:02, 06 Jan.
10:07:56, 06 Jan.
dsl:VDSL Link Down: duration was 99 seconds
10:06:49, 06 Jan.
10:06:17, 06 Jan.
10:06:17, 06 Jan.
10:06:17, 06 Jan.
10:06:17, 06 Jan.
