Moderator
Moderator
Message 11 of 14
Re: Hub keeps dropping broadband connection
@McSure I was calling there but missed you, I'm really sorry I can see the connection has continued to drop out over the weekend and we're going to need to get you another engineer visit booked. Is there a day this week that would suit?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
McSure
Message 12 of 14
Hi Neil tomorrow, or any morning this week.
Nigel
Moderator
Moderator
Message 13 of 14
Hi @McSure I see the engineer has changed your line, I'll follow up with you again on Monday to check if this has worked.
Kudos”Kudos”
Moderator
Moderator
Message 14 of 14
Hi @McSure I called there but missed you, can you let me know if you're happy the problem has been resolved by the last engineer?
Kudos”Kudos”
