DigitalDave
Message 1 of 4
Hub5 or Hub6 ?
After negotiating a new contract I was offered and sent a shiny new Hub 6. My present Hub 5 with a hard wired repeater (made from a Hub 3) is problem free, so other than having a spare in the cupboard any advantage in swapping them?
Another question for the Gurus, can I replicate hub name and password in the new hub so it would be an invisible swap over....if that makes sense.
3 REPLIES 3
gg30340
Message 2 of 4
Re: Hub5 or Hub6 ?
If it ain't broke don't fix it!
licquorice
Message 3 of 4
Re: Hub5 or Hub6 ?
Keep it as a spare, don't swap it unless the old one fails.
If you do need to use it, you can give it the same SSID and password as the old one.
DigitalDave
Message 4 of 4
Re: Hub5 or Hub6 ?
Thanks for confirming my own thoughts. I just wanted it confirmed that there was no technical advantage...so it's off to the cupboard for the brown box.
