Message 1 of 1
Hybrid Connect once week drop out
Is there anyone in there Who has BT Halo 3+ and has Hybrid Connect Does anyone one that there issue where the Hybrid Connect light goes red and will disconnect from smart Hub 2 3 times and try to reconnect itself back to the hub? Will disabling the SSID of wifi of the hub mean you can no longer use wifi from the hub
Tags (1)
