Message 1 of 4
I can't track my order
I ordered BT boardband on the 5 feb 2025 switched from talktalk.  I didnt get order confirmation on my email and can't track it. Do I have to wait longer?
3 REPLIES 3
Message 2 of 4
Re: I can't track my order
have you set up a BTID so you can access MYBT where you should find information about your order
Message 3 of 4
Yes, I activated my BTID and it says inactive.  I cant track my order, its loading forever. Got email from talktalk saying there is £4 charge for leaving. Did my order went through?
Message 4 of 4
you need to check with CS 03301234150 or you can try message now to billing  https://www.bt.com/help/contact-bt/account-and-billing/broadband
