Message 1 of 4
I haven't been happy with my slow speed for awhile now, it feels like I'm capped
I used to get around 45mb for about 6 months, it was great but then it started to get slower and slower, and less stable until eventually, I hit 29.99mb (no matter what it won't budge from this, so it seems to be capped?). I had an engineer out and he fixed some errors on the line which made it stable again, but the speed never improved. I would happily pay more for a better speed if possible, but at the very least I'd like my old speed back which was so much better. Is this really the best my line can handle?
3 REPLIES 3
Message 2 of 4
Re: I haven't been happy with my slow speed for awhile now, it feels like I'm capped
Looks like you may be in a banded profile due to all your previous line problems.
Can you post your hub/router stats
Message 3 of 4
Product name,BT Smart Hub 2
Serial number,+091299+1951000375
Fireware version,v0.27.06.04290-BT (Thu Apr 29 20:28:10 2021)
Board version,R01
GUI version,1.74 12_11_2020
DSL uptime,0 days 10 Hours 4 Mins 20 Secs
Data rate,7.0 Mbps / 30.0 Mbps
Maximum Data rate,7.0 Mbps / 37.2 Mbps
Noise margin,6.3/8.8
Line attenuation,10.7/25.3
Signal attenuation,10.7/25.9
VLAN id,101
Upstream error control,Off
Downstream error control,Off
Data sent / received,1.3 GB Uploaded / 2.1 GB Downloaded
Broadband username,bthomehub@btbroadband.com
BT Wi-Fi,Active
2.4 GHz wireless network name,
2.4 GHz wireless channel,Smart (Channel1)
5 GHz wireless network name,
5 GHz wireless channel,Smart (Channel36)
Wireless Security,WPA2 (Recommanded)
Wireless mode,Mode 1
Firewall,On
MAC address,
Software variant,-
Boot loader, 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 4
Connection time is only 10hrs is that due to router dropping connection or manual reset?  You really need a stable connection with no drops/resets for 3/4 weeks before DLM will start to release banding and speed increase
