Message 1 of 3
I'm impressed!
My BT fibre optic internet wasn't working yesterday so I reported it. This morning, the BT engineer came and found that my Shetland pony had gnawed through the cable! BT have put in a new cable and I'm up and running again. This is impressive as the problem was solved in less than 24 hours. Thank you, BT!
2 REPLIES 2
Message 2 of 3
Re: I'm impressed!
Guess you won't be impressed when you get the damage repair bill.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Re: I'm impressed!
Hi @Kathy2,
Thank you for posting back. I'm happy to see that your service was repaired so quickly.
Paddy
