Message 1 of 9
I’m struggling with bridge mode on my Business Smart Hub 2
At my previous address I had Virgin Media, and I just enabled bridge mode and everything worked great. The rest of my network is a series of Eeros/managed switches which I’m very happy with.
When I moved I didn’t have many choices, so I originally got BT residential broadband, FTTC, which is so slow in comparison - but my property sadly has neither Virgin nor FTTP currently available. (If anyone has any ideas on how to get them to run the cables, I’d love to hear them!). The residential BT Smart Hub 2 does not support Bridge Mode, annoyingly.
So I spoke to BT, and they told me if I got business broadband I’d be able to use Bridge Mode. So I upgraded, and they sent a new hub and fitted a new socket with a filter built-in. The new hub looks EXACTLY the same - I assume it just has a different firmware. Seems a bit mean not give the same router features to everyone! Anyway.
When I enable Bridge Mode on the SH2, I get completely inconsistent results. The first time the light went amber, which I believe is what’s supposed to happen. After clicking Save, the admin site never reloads, but this is expected behaviour I think - since that IP is no longer available. But the Gateway Eero never connected to the Internet. So I factory reset the SH2, and tried again, and it failed again, and I gave in for a while. A week later, I tried again and this time it worked! For a while. Until it stopped working a few days later. Then I had to factory reset it again. It works fine in Double NAT mode, but that’s causing issues with various bits of software I need to run for work.
Today I enabled Bridge Mode, and the admin site reloaded (which is weird) and showed Bridge Mode was enabled. But when I run traceroute, I still see Double NAT. And the light remained blue. I turned it off and on again, the light stayed blue. I went into the interface, and turned off and on Bridge Mode. Then it failed to reload (which struck me as a positive thing), but the light stayed blue, and even after rebooting everything I STILL have Double NAT. The Eero is showing its DHCP server as 192.68.1.254 - so I don’t think the Business SH2 is actually in Bridge Mode.
And then today I had to turn power off, when it came back on the light was orange and nothing worked anymore. So I’ve put it back into standard mode, with the Eero in the DMZ. It’s more reliable, but my work VPN doesn’t work anymore - it only worked in the brief moment when Bridge Mode worked correctly.
Is there some magical thing I need to do for Bridge Mode to actually work? Should I be using a Static IP, or connecting the Eeros to the WAN port instead of a LAN port?
Technical support said they never hear from anyone using Bridge Mode, so couldn't help much. They're sending me a new SH2 to try out, but it seems unlikely it will be a hardware issue.
I’m hoping someone here can help!
8 REPLIES 8
Message 2 of 9
Re: I’m struggling with bridge mode on my Business Smart Hub 2
@booshtukka
Welcome to the BT Residential Customers forum
As you now have a business account, please could you post on the BT Business forum at http://business.forums.bt.com/
Message 3 of 9
Why on earth have you wasted money with a business account just to get a modem?
You could have kept your residential service and bought an Huawei HG612 from eBay for peanuts.
Message 4 of 9
It cost 60p more a month and I have a lower contention ratio - so I don't feel too hard done by 🙂
Message 5 of 9
Fair enough, you got a bargain.
Message 6 of 9
If you have the hub in bridge mode, you need to connect one of its LAN ports to the WAN port of your Eeros.
You will need to ask on the business forum what the WAN details are as you will have a static IP address and a discrete login as opposed to the generic residential details.
Message 7 of 9
I don’t have a static IP. The eero doesn’t have a dedicated WAN port - it should work in either. I’m asking on the business forum too - thank you.
Message 8 of 9
If the hub is in bridge mode, you need a router with a WAN port.
Message 9 of 9
Yes, the Eero has two ports and either can act as a WAN or LAN port. As mentioned, this configuration worked fine with a Virgin router in Bridge Mode.
Merry Xmas. 🙂
