cobhc
Message 1 of 15
IP Profile Reset
Hello,
How would I go about requesting an IP profile reset? My attainable rate has dropped recently and my line seems to be fine so I believe a reset would allow me to again sync at a higher speed.
I've tried the master socket and still the same, I'm using a Huawei HG612 and my stats are below:-
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:0
Last initialization procedure status:0
Max:Upstream rate = 21789 Kbps, Downstream rate = 66744 Kbps
Bearer:0, Upstream rate = 19999 Kbps, Downstream rate = 67338 Kbps
Bearer:1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:L0
Mode:VDSL2 Annex B
VDSL2 Profile:Profile 17a
TPS-TC:PTM Mode(0x0)
Trellis:U:ON /D:ON
Line Status:No Defect
Training Status:Showtime
DownUp
SNR (dB): 4.2 7.1
Attn(dB): 16.7 0.0
Pwr(dBm): 12.7 7.0
VDSL2 framing
Bearer 0
MSGc:-626
B:243237
M:11
T:042
R:1016
S:0.11540.3781
L:176115374
D:81
I:254127
N:254254
Q:80
V:00
RxQueue:760
TxQueue:190
G.INP Framing:180
G.INP lookback:190
RRC bits:024
Bearer 1
MSGc:154-6
B:00
M:20
T:20
R:160
S:6.40000.0000
L:400
D:30
I:320
N:320
Q:00
V:00
RxQueue:00
TxQueue:00
G.INP Framing:00
G.INP lookback:00
RRC bits:00
Counters
Bearer 0
OHF:0686646
OHFErr:064
RS:940663443056621
RSCorr:1798053176
RSUnCorr:00
Bearer 1
OHF:1696490
OHFErr:00
RS:16958750
RSCorr:00
RSUnCorr:00
Retransmit Counters
rtx_tx:81238320
rtx_c:210
rtx_uc:00
G.INP Counters
LEFTRS:00
minEFTR:673240
errFreeBits:27985670
Bearer 0
HEC:00
OCD:00
LCD:00
Total Cells:3528439170
Data Cells:340842870
Drop Cells:0
Bit Errors:00
Bearer 1
HEC:00
OCD:00
LCD:00
Total Cells:00
Data Cells:00
Drop Cells:0
Bit Errors:00
ES:015
SES:09
UAS:2222
AS:2726
Bearer 0
INP:51.000.00
INPRein:1.000.00
delay:00
PER:0.003.98
OR:0.0164.22
AgR:67407.3020063.54
Bearer 1
INP:4.500.00
INPRein:4.500.00
delay:30
PER:16.060.01
OR:79.680.01
AgR:79.680.01
Bitswap:2222/2222378/378
Total time = 45 min 48 sec
FEC:1798053176
CRC:064
ES:015
SES:09
UAS:2222
LOS:00
LOF:00
LOM:00
Latest 15 minutes time = 48 sec
FEC:50770
CRC:00
ES:00
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Previous 15 minutes time = 15 min 0 sec
FEC:583337
CRC:02
ES:02
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Latest 1 day time = 45 min 48 sec
FEC:1798053176
CRC:064
ES:015
SES:09
UAS:2222
LOS:00
LOF:00
LOM:00
Previous 1 day time = 0 sec
FEC:00
CRC:00
ES:00
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Since Link time = 45 min 25 sec
FEC:1798053176
CRC:064
ES:015
SES:09
UAS:00
LOS:00
LOF:00
LOM:00
14 REPLIES 14
Sage
Sage
Message 2 of 15
Re: IP Profile Reset
What do you mean by relatively quiet? When using the quiet line test it should be silent but for the announcements. 17070 option 2.
Is it just your attainable the has dropped or actual?
Put your phone number in HERE and post results. Remove phone no before posting.
cobhc
Message 3 of 15
Sorry, yes the line is silent. And that site seems to be down right now but I'll try again tomorrow.
My actual speed has dropped as well as attainable, I'm seeing just below 60mb rather than around 70 like I had been previously.
Message 4 of 15
your connection speed at 67mb is slightly above attainable so connection looks ok and your profile is based on your connection speed not the other way round.  there is no guarantee on download speed.
As quiet line test is silent then you are basically getting very good speed for your line and not reset is required
cobhc
Message 5 of 15
Here's the requested information for completeness. Is it just something I'm going to have to live with that the speed has dropped? Is it just the cabinet filling up, etc?
Message 6 of 15
your connection speed is still within the expected range
which exchange and cab are you on?  you deleted that at same time as number
cobhc
Message 7 of 15
So because it's within the expected range, the speed drop recently is down to factors that are outside of anyone's control? If so, that's disappointing but fair enough.
Apologies, the exchange is BURTON JOYCE and I'm on Cabinet 2.
Message 8 of 15
did you change package or have you been having problems with dropped conenction?
you have lost G.INP which resulted in drop in speed.  if your connection now remains stable for 7/10 days then DLM will activate G.INP again which should give speed boost you are looking for
cobhc
Message 9 of 15
I have had a few drop outs, yes so that's probably it. I'll keep an eye on things over the next few weeks then, thank you.
Message 10 of 15
if you have had drops in connection have you checked your phone line for noise   dial 17070 options 2  should be silent and best with corded phone from test socket   any noise is a problem and need reported as phone fault to 151
