pompey1898
Expert
Message 11 of 15
Re: IP Profile Reset
@cobhcwrote:
Here's the requested information for completeness. Is it just something I'm going to have to live with that the speed has dropped? Is it just the cabinet filling up, etc?
This shows you got 75.95 yesterday
Message 12 of 15
@pompey1898
I saw that hence why I asked for exchange and cab which confirmed Huawei and the speed drop was the loss of G.INP which with a stable connection should be activated again by DLM
cobhc
Message 13 of 15
12 days now with no disconnections and still stuck at a lower speed though technically slightly higher. I'm guessing this may be just the way things go. I reset the modem today just to see what happened and still the same.
# xdslcmd info --stats xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 21661 Kbps, Downstream rate = 66960 Kbps Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 68007 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 4.1 7.2 Attn(dB): 16.6 0.0 Pwr(dBm): 12.7 6.9 VDSL2 framing Bearer 0 MSGc:-626
B:243237
M:11
T:042
R:1016
S:0.11420.3781
L:177865374
D:81
I:254127
N:254254
Q:80
V:00
RxQueue:760
TxQueue:190
G.INP Framing:180
G.INP lookback:190
RRC bits:024
Bearer 1
MSGc:154-6
B:00
M:20
T:20
R:160
S:6.40000.0000
L:400
D:30
I:320
N:320
Q:00
V:00
RxQueue:00
TxQueue:00
G.INP Framing:00
G.INP lookback:00
RRC bits:00
Counters
Bearer 0
OHF:02225182
OHFErr:040
RS:3079862323222067
RSCorr:733592410
RSUnCorr:00
Bearer 1
OHF:5498510
OHFErr:00
RS:54978990
RSCorr:30
RSUnCorr:00
Retransmit Counters
rtx_tx:82423530
rtx_c:2960
rtx_uc:00
G.INP Counters
LEFTRS:00
minEFTR:679950
errFreeBits:91590170
Bearer 0
HEC:00
OCD:00
LCD:00
Total Cells:11550354570
Data Cells:212084090
Drop Cells:0
Bit Errors:00
Bearer 1
HEC:00
OCD:00
LCD:00
Total Cells:00
Data Cells:00
Drop Cells:0
Bit Errors:00
ES:033
SES:00
UAS:2323
AS:8833
Bearer 0
INP:51.000.00
INPRein:1.000.00
delay:00
PER:0.003.98
OR:0.0164.22
AgR:68077.1220063.54
Bearer 1
INP:4.500.00
INPRein:4.500.00
delay:30
PER:16.060.01
OR:79.680.01
AgR:79.680.01
Bitswap:6916/6916623/623
Total time = 2 hours 27 min 36 sec
FEC:733592410
CRC:040
ES:033
SES:00
UAS:2323
LOS:00
LOF:00
LOM:00
Latest 15 minutes time = 12 min 36 sec
FEC:694407
CRC:02
ES:02
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Previous 15 minutes time = 15 min 0 sec
FEC:11450332
CRC:04
ES:03
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Latest 1 day time = 2 hours 27 min 36 sec
FEC:733592410
CRC:040
ES:033
SES:00
UAS:2323
LOS:00
LOF:00
LOM:00
Previous 1 day time = 0 sec
FEC:00
CRC:00
ES:00
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Since Link time = 2 hours 27 min 11 sec
FEC:733592410
CRC:040
ES:033
SES:00
UAS:00
LOS:00
LOF:00
LOM:00
Message 14 of 15
from stats you have 68mb connection speed with noise margin at 4.1db and your estimated speed range is between 80/60mb so you are in the range just nearer bottom than top.  if you are going to get a few more mb in connection speed it ill happen by just leaving router connected 24/7.
if it managed 70mb eventually would you really notice any difference from 68mb?
cobhc
Message 15 of 15
Thanks for the reply. As mentioned before it is more because the speed used to be in the mid 70's which is a fair bit higher than now but I understand I am still within what I should be getting.
