Message 1 of 4
IP Profile now 55mbps
Hil All, my broadband speed used to be no lower that 75 mbps, I tested the connection regularily. However, I started to notice a speed drop, and when I checked the BT wholesale test, it states that my profile hase been set at 55 mbps. Does anyone know how this has happened and how I can revert it back to it's previous speed?
Many Thanks
3 REPLIES 3
Message 2 of 4
Re: IP Profile now 55mbps
Can you post the full connection stats from your router, as well as a screenshot of the results for your line from https://www.dslchecker.bt.com
Message 3 of 4
Is this what you mean?
This is a quick overview of your BT Smart Hub's status.
Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4 :
BT Infinity
Firmware version:
SG4B1000B316
Firmware updated:
31-Jul-2017
Serial number:
+084319+NQ61821312
Downstream sync speed:
60.00 Mbps
Upstream sync speed:
10.39 Mbps
Network uptime:
0 Days, 17 Hours 10 Minutes
System uptime:
7 Days, 16 Hours 26 Minutes
BT Wi-fi status:
Active
Sage
Message 4 of 4
No, not the quick overview.
HERE tells you how to get the full stats depending on which hub you have.
