martpu
Expert
Message 1 of 7
IP Profile shows 83.63 Mbps on 80/20???
Afternoon guys.
Haven't been on here in a while so my apologies if this has already been raised but I've just ran a BT Speedtester test and my IP Profile is showing as 83.63 Mbps, yet since I had Infinity 2 activated on launch day, it's never been higher than 77.43 Mbps and that was only for the first week or two (it's averaged 65-74 Mbps since then).
The broadband has been connected for over 10 days, I did run a test maybe 5/6 days ago and the IP was around 74 Mbps so I've not had a disconnection yet my IP has apparently increased.
Is this another glitch in the system???
________________________________________________________________________
You won't get to ride the racehorse...until you've ridden the mule.... - RogerB 13/04/2010
6 REPLIES 6
MBR123
Expert
Message 2 of 7
Re: IP Profile shows 83.63 Mbps on 80/20???
Can you log an Img mate of your diagnostic check here.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
martpu
Expert
Message 3 of 7
 Here you go mate!
walkerx
Recognised Expert
Message 4 of 7
this is what i'm syncing at     and this is from bt spee...
and this is from bt speedtest
the profile will change on a regular basis and i have seen mine around 78Mbps
martpu
Expert
Message 5 of 7
Re: this is what i'm syncing at and this is from bt spee...
I could be wrong but I assumed you couldn't have an IP Profile above 80 Mbps and even if you could, I didn't think the IP could change without the broadband re-establishing a new connection even though mine has changed in the last couple of days yet I've been connected for over 10 days?
walkerx
Recognised Expert
Message 6 of 7
i think the main page is wrong as it shows my max to be 0Mbps
But your profile will constantly change on a regular basis
If you had a modded modem or used the draytek you will see your attainable rate constantly changing
I do know of some people that have an attainable rate of 125Mbps
martpu
Expert
Message 7 of 7
Agreed, the page is definitely wrong but that still doesn't explain the >80 Mbps IP as I didn't think it was possible to exceed this on an up to 80mb package?
Either way, I'm 'only' getting 70mb according to the test so I guess it doesn't matter!
